Stock 98 M6 .bin needed (HPT)
attached is a read from my 1998 ws6 m6 (160 speed limiter) as reflashed from a tech 2 back in january 2006.
I hope this helps.
Warning: whenever you do any reflashing of any 1998 PCM's you must make sure the file is good, and if you get any checksum issues the pcm is toast.
Ryan
I hope this helps.
Ryan
very little needs to be changed. going the other direction you need more tables to set up for the A4 but for the M6 it ignores the A4 stuff, zero out the P/N idle cells, make the IN DRIVE & IN PARK/N idle spark tables the same, copy in some stall protect tables, turn off any DCT's dealing with trans, disable ABUSE mode, zero out trans diag tables, should be it.
LS1TECH Sponsor
I hope this helps.
Ryan
I hope this helps.
Ryan
I really don't want to have a tech2 reflash my PCM. Also I really don't want to fry the PCM either. Would I be safer to do as described above. Is this all the tables that need to be moded to work?
LS1TECH Sponsor
There are actually several, the one he was using had no vcm id number which could cause licensing problems for him now & in the future so I suggested he have it flashed to a valid stock file, the repository files really are there for nothing more than viewing, I would never recommend flashing one of them to your pcm especially the 98 pcm's.
