85mm Maf Calibration Values
Old Apr 22, 2008 | 02:39 PM
Jpr5690's Avatar
Default 85mm Maf Calibration Values
Anyone Wanna Share Their Maf Calibration Tables For A 5 Wire 85mm Maf In A F-body
I Have A Set Of Values And Im Gonna Be Re-calibrating My Maf Here Soon; But Id Like To Take A Look At What Other's Are Using Just For My Sanity
Old Apr 23, 2008 | 08:11 AM
Jpr5690's Avatar
Dam!...........
Old Apr 23, 2008 | 02:41 PM
jimmyblue's Avatar
Moderator
On your car we used the truck ("ZL1" so called) table but I found
the Z06 table better after the cam swap. However if you have any
errors like high fuel pressure etc., the result may still not come out
right. I'd get a fuel pressure reading at WOT and make sure you
have IFR table tweaked up for actual / rating pressure on whatever
injectors you have.
File Type: zip
Old Apr 23, 2008 | 03:35 PM
Jpr5690's Avatar
Isnt There A Fuel Pressure Regulator From The Factory?
My Ifr's Are Based On 58psi So Im Hopeing This Is Accurate.. I Know With My Racetronix Setup I Should Be Good As Even Before The Kit I Had Good Fuel Pressure
With My Current Maf Table I Command 12.2 But I Get 12.8@4000rpms And It Just Rises To 13.5@6800rpms
SOON AS I GET THIS EGR\WIDEBAND FIGURED OUT IM JUST GONNA MAKE A NEW MAF CALIBRATION BUT I INDA WANT TO LOOK AT OTHER CURVES JUST FOR MY SANITY
Old Apr 23, 2008 | 03:43 PM
Jpr5690's Avatar
Wouldent Using The Z-06 Tabel Vs The Z-71 Tabel Lean Out The Car Even More? (it Shows Less G\sec)
For My App... I Was Thinking Of Sometyhing Like The Holden Monaro Tabel
BTW COOL FILE
Old Apr 24, 2008 | 09:54 AM
Frost's Avatar
you will have to go over the MAF table with a wideband regardless of what you use for a base file, so it doesn't really matter which one you start with
Old Apr 24, 2008 | 09:59 AM
Eurospec2's Avatar
Yep
Old Apr 24, 2008 | 10:27 AM
Jpr5690's Avatar
I Know, I Was Just Looking For A Comparison File..
