car feels "sluggish" every now and then
Hey all,
I don't know if this is in the right section or not, but, I thought it was. If it isn't sorry.
Anyways, the motor in question is the one in my sig. It has a full manual 4L80e. It usually drives perfectly, however, it does something somewhat annoying every now and then. When I drive it as soon as starting it up (I tend to give it a minute on normal days, longer on cold days) it will feel sluggish. By sluggish I mean it drives like you are trying to drive a 6-speed from a standstill in second gear. It sounds completely shitty as well. It will continue on up through 2nd gear. Usually, if I go WOT real quick the problem is solved. It also does it if the car has been sitting at idle for a long time. Like, if there is a really long stoplight or if I am at a drive thru it will happen occasionally. Like I said, it doesn't happen all the time and is always cured by a quick WOT.
The car has been dynotuned by Ed Wright from Fastchip. It has LS7 fuel injectors but I am still on a stock fuel pump.
Could the fuel pump be the issue? Could it be the tune? What are your all's thoughts.
if its thorwing a code you might want to check the o2 sensors, i had that problem, also you may want to change out you fuel fliter, its cheap and easy so it want hurt if that aint the problem but i was running a little odd and changed mine and now it runs better, and you might want to throw in some injector cleaner
did the car do this before the tune or after? if it started doing this after the tune i would head back to your tuner and tell him everything word for word the car is doing other than that injector cleaner, fuel filter, spark plug change even maybe.....
