What would make me go rich after Letting off throttle?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I am cruising down the road with WB at 14-15 afr let off the throttle completely and it goes pig rich 12-13 afr until car is stopped.What do I need to look into?Keep in mind the Car is Tuned in Open Loop only.
Thanks
Thanks
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
If your minimum injector pulse width is greater than
what the closed-throttle airflow can burn off, you will
see rich readings. I think this is what DFCO is about,
like if you can't control it clean then cut it off altogether.
Fuel economy is a bonus, stanky pipe gets you flunked
at platform EPA certification.
An online calculator got mine more or less. I just filled in for different "idles" and kpa ect ect. The calculator stated my idle was 2.8 ms at 34 kPa so I plugged in 20kPa and shoved that in as the min pulse for that RPM cell. Jacked up the RPM value and used that as the next min pulse cell.
With this I believe you could make very educated guesses at what it would be if there was instanst opening and closing of the injectors and the fuel got there instanstly and then stopped instanstly.
http://www.rbracing-rsr.com/calcinjpulse.html
