alarm won't stop going off after last night's rain
Old 08-01-2013, 01:33 PM
Mr Phil's Avatar
Exclamation alarm won't stop going off after last night's rain
so I have a slight problem now, after a crazy rain storm we had last night, any time I lock my car within a couple of minutes my alarm starts going off... has anybody ever had this happen to them before? I don't really feel like leaving my car unlocked all the time now
Old 08-01-2013, 03:34 PM
Mr Phil's Avatar
Anyone?
Old 08-01-2013, 08:45 PM
Mr Phil's Avatar
Old 08-01-2013, 11:32 PM
Mr Phil's Avatar
How very helpful of you guys
Old 08-01-2013, 11:38 PM
1999CamaroSS's Avatar
If you opened your trunk at all while it was raining/trunk had water on it I can almost guarantee that you got your shock sensor wet. Open your trunk and pull off the plastic trim covering the passenger side wheel well, you will see a small black plastic box on the wheel well, unplug the power to it, and allow the thing to dry out for a few days before plugging it back in. (It's possible that it needs sensitivity adjustment but try this first.)
Old 08-02-2013, 12:34 AM
01WS6/tamu's Avatar
Guarantee shock sensor got wet either from hatch open or it will run underneath the rubber over the pinchweld and flood the shock sensor.
Unplug it try it for a few days.
Old 08-02-2013, 02:17 AM
Mr Phil's Avatar
Trunk never was opened, it was just going off wheni got out from work, I've unplugged the sensor, but when I looked at it andit was completely dry even in the spare compartment it was dry as well
Old 08-02-2013, 03:41 PM
Nathan C's Avatar
You can always use the key to manually lock your doors w/o setting the alarm.
Old 08-02-2013, 08:47 PM
Mr Phil's Avatar
If I had a key I would lol
Old 08-02-2013, 10:39 PM
But did unplugging it help?
Old 08-03-2013, 03:10 AM
Mr Phil's Avatar
Yea so far so good
Old 08-03-2013, 07:40 AM
That's MISTER MODERATOR
Paul Bell's Avatar
You could disconnect the battery for a while and let everything reset.
Old 08-03-2013, 04:19 PM
Mr Phil's Avatar
I was gonna ask something in regards to that.... if I get a custom dyno tune done and have to disconnect battery for whatever reason to reset things, will I lose the tune as well or is it embedded in?
Old 08-04-2013, 09:59 AM
01WS6/tamu's Avatar
Once the alarm is in a tripped state it stays that way unless unlocked with a transmitter. Disconnecting battery wont help because if it did all thieves would know how to steal em.
Old 08-04-2013, 12:33 PM
Mr Phil's Avatar
Well its only the factory alarm, and I turned the alarm on and off multiple times with the clicker but as soon as I armed it again, it goes off.... I haven't connected it back yet cuz I don't want to deal with issues anymore
Old 08-04-2013, 02:50 PM
hawk584's Avatar
is there water in your tail lights?
Old 08-04-2013, 04:32 PM
Mr Phil's Avatar
Nope nothing
Old 08-05-2013, 07:06 PM
01WS6/tamu's Avatar
Is the shock sensor disconnected and it's still going off?
If alarm quit going off once shock was disconnected it's fragged.
OE keyless remote must be used to disarm once triggered it won't disarm any other way.
Old 08-05-2013, 11:20 PM
Mr Phil's Avatar
no it stopped going off once the sensor was disconnected, but the problem was I did deactivate it with the OT remote and it would still reactivate once I would arm the car again
but as far as my other question does anybody know about dyno tunes and disconnecting the battery if you will lose your tune?
Old 08-05-2013, 11:34 PM
01WS6/tamu's Avatar
Tune is permanently in pcm's memory it will not be lost by disconnecting the battery.
Quick Reply: alarm won't stop going off after last night's rain
