Buddy just bought a G8 GXP, suggestions and pointers?
My buddy pulled the trigger today on a 2009.5 G8 GXP with a manual 6 speed/LS3. He will likely be doing a Vararam Intake and Solo Axel-Back exhaust for his first mods. It's intended purpose is to be a nice, roomy family car, but also for going to car shows and having some fun in.
Neither he or I know much about modding G8's, is there other things that should be considered for basic mods? I see deleting DOD out of the tune is a common mod, but he does prefer the gas mileage as well. Any suggestions are appreciated!
Check the bushings and ball joints for wear and see if they were given the in warranty recall, or if he should upgrade. A lot of people run maggies on these cars, and they sound/run very nice without the DOD, better cam and full flow duels.
He probably won't get too crazy with this one, just a fun car. I just didn't know if there was any "must-do's" when it comes to modding these. I know there is some crazy weight savings to be had with full exhaust, but other than the typical bolt-ons and rims/tires, he probably won't do anything too crazy.
Car only has 30k miles on it, but how do you check the ball-joints and bushings properly?
Put it on a lift, remove the tires and see if you can see cracks or separation in the Rubber compound inbetween the links on the suspension. If you do see cracks or separation, they need to be swapped. You could also take it to the dealer and have them check for a "knocking" sound over bumps at an angle, this car is still under the 5 year warranty.
I would personally swap out the rims as they look too thin, the Camaro rims look sweet on this car but are heavy. Maybe the stock GT Alloy Rims, the ones without the notches in the post from the center hub to outer shell.
The solo axel back does sound great and looks very easy to put on though.
I've considering looking into getting a V6, possibly a GT model as a daily in the next few years when it's time to replace my buick. Very nice cars.
Long tube headers with catted mid pipes and Solo axlebacks will give him power and sound without the drone, since the axlebacks have adjustable J pipes. It'll be loud thought since the Solo axlebacks don't have mufflers. Solo does make some tube style resonators that can be welded into the mid pipes. That I think would be the best setup for the G8.
Looks like my wife's car. G8 GXP M6 in SRM. It still has the polished gxp wheels though. All I've done performance wise is a rotofab. Plugs were pretty easy to do. They don't last more than 40k miles though. If he is wanting a little more noise, he can unbolt the mufflers and see if he likes the sound or just until he makes a decision. It still has the large resonator in the middle of the car. HID's are a great addition in place of the low beams. He'll probably need to change the clutch fluid regularly. It gets dirty quick and makes the pedal stick. When this first happend we took it back to the steelership who wanted to put a new clutch in $$$$. I took it home and changed fluid in the reservoir and pumped the pedal and changed until it was clean and it fixed the problem. We haven't had any suspension issues in over 50k miles. Battery went out last summer though.
