Audio System Cuts Out
![Angry](https://ls1tech.com/forums/images/icons/icon8.gif)
I find that when I play the music loud after about fifteen minutes the radio cuts out and I don't hear anything. I guess this is a governor for the audio system. Is there any way to remove it? also, has anyone replaced the stock amp...would that help?
I have turned off the distortion limiter, the EQ, and the speed sensitive volume and mine still cuts off....... Haven't turned up the stock amp yet. Everyone I have asked says that there is nothing that can be done except for not cranking the stereo
![Icon Rolleyes](https://ls1tech.com/forums/images/smilies2/icon_rolleyes.gif)
well, if we could limit it down to what is over heating we could solve the problem with cooling. maybe someone should turn the sub amp down all the way and see if it is sensing that over heating or if its the HU internal amp for the main speakers.
How can i put this with out making my car sad. I don't really like the stereo system....when you want to turn the volume up it isn't even loud. And when the bass is over 3 and it is "loud" like at 62 vol. or it is on the Auto EQ. the bass is just hitting to hard and makes my speakers sound distorted. I truly believe these speakers are too weak for the stereo head unit and amp. maybe i am doing something wrong but as of right now i have it set to Bass at 2 and Treb. at 5. i think something could be changed. and as for that auto volume control i tried to remove that i think it still goes up in volume with my speed....it is on the off position. Who the hell knows
Kristen Jankovich
Kristen Jankovich
Kristen I compleyely agree...the head unit and amp are real nice on these cars...I think the speakers just aren't up to spec. BTW nice choice on the combo u have! I just picked up my Blue/black/m6 last week!
You can turn up the bass on the amp so that it sends more to the subs, and you can actually lower the bass setting on the head unit. I did that on mine and found I can listen to it longer before it cuts out. Your amp is on the driver's side of the trunk, on the inner 1/4 panel. Pull back the carpet on the side of your trunk and you can see it. Unscrew it, and you will see the adjustment *****.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Hope that helps a bit.
