adjusting pedals for heel toe
Since only the throttle sits lower, it would seem easiest to adjust/shim this pedal upwards to make them all flush. Is this possable and can it be done and not screw up the tps/ecm and wide open position with the throttle body?
thx,
Ryan
practice and itll work just fine. i wouldnt start messing with bending the pedals. you can get aftermarket pedals that screw into your stock pieces. i got a set, and the extra material on the gas pedal helps.
(all I mean is, keep in mind that "flooring it" will be pulling extra tight on the throttle cable). You may want to try the aftermarket pedal covers first, as was suggested.BTW, I see you're from Kingston ... where are you running that you're concerned about heel/toe anyway? Do you run any track events or auto-x in Ontario?
We just started sponsoring LS1TECH. My company, SRP, specializes in race pedals for performance use. Check out the thread below for more info and a 20% off discount code.
https://ls1tech.com/forums/sponsor-s...ls-20-off.html
Our pedals offer improved heel toe sizing, better grip, and easier height adjustability. Once installed, you can fine tune the height relationship between the gas and brake by "shimming" whichever pedal needs it. On every car I've owned my brake pedal was too low for easy heel toe. After I bolt on our pedals (you do have to drill to mount), I then remove the brake pedal. Then I put some flat washers between the factory brake and the new aluminum brake pedal and shim it to a better height so that heel to is effortless.
Hope this makes sense and helps.
Brian
I've perfectly matched downshifts in a slide on a autoX course with National Champion instructors sitting shotgun.... it's about HOW you do it not where the pedals are.
In fact get a good set of driving shoes. I personally like Piloti Prototipos
Bret
Bret
I know I am selling pedals, so I might be a little opinionated. But, if your brake pedal gets too low under hard braking relatative to your gas, and your ankle isn't comfortable bending that far or that angle, pedals will help. If your brake and clutch are too far apart, pedals will help. If you are blipping the throttle with half your foot hanging off the brake pedal, more grip is a very good thing to have.
Being comfortable while driving is crucial to being smooth and fast. Seat, pedals, wheel, shifter. These are what you use to interact and become one with your car.
Brian
I fashioned a brake pedal out of cardboard to accomadate my club feet as I H/T as EchoMirage has described.
Using a hacksaw, I roughly cut out the desired shape and then used a sheet of sandpaper to smooth out the edges and cut lines.
I drilled 6 holes in the newly fashioned pedal cover, and used #6 flat head wood screws to afix it to the stock pedal. Placement of the screws is critical. You don't want to interfere with the pivoting points.
If a 1/4" isn't enough height, build 2 and stack them. I would use some modelers glue to hold the pieces together, though.
Cheap, easy and took me about 1/2 hour from start to finish, not including the check-out line at Wal-mart. :roll:
now on my CMC 4th gen, i have a brake pedal cover from them and after 2 weekends of using it, i dont know how i got by the last 4 years w/out it. this past weekend was wet all weekend and not one slip off the brake pedal while "heal toe'ing".
i highly recomend them for street or track.
While I'm here, a couple of pictures (Porsche pedals).
New options now available: The Grid Trim Rings and Grid machining on the gas and footrest. The Grid Trim Rings are the borders machined around the edges of the pedals. These options are NO-COST. Pictures of pedals with these options are below.
www.srpracing.com
