Best "race" springs?
I've been doing some research on springs and it seems that most of the springs are a little on the soft side for road racing or autocross. Does anyone have any suggestions on what springs to get if I plan on doing a lot of racing and am not worried about how the car feels on the street. There was a post on spring rates a little while back and the Eibachs seem like they wouldn't be stiff enough. From what I can tell the stiffest springs available are the Suspension Techniques? I also plan on getting Koni SA's...Suggestions??
It's very hard to get stiff springs for an fbody. The problem is, it's a unit body so the manufactures don't want you to twist your car into a pretzil then blame them. I'm using cut down 1LE springs with Koni shocks; that makes a pretty stiff setup, but I wouldn't recomend it with out subframe connectors or a roll cage to stiffen the chassis. I have both.
the G2 springs can only be found used. and good luck finding them. Lou has had issues w/ getting them made cause they want him to buy like 250 sets @ a time. other than that, look into his coilover set-up. this is a no **** track set-up that you would be very happy w/.
H&R stage 2 (now called "sport springs"). I calculated 647 in lb front and 258 rear. Another board member said H&R quoted him 590 for the fronts a few years ago. Either they have changed or my math is slightly off (probably #2). They have a good bit of spring rate, you may want to try them. I like mine.
If you decide not to get coilovers I think the G2 spring rates are just about right on for most road race setups, as long as you're running sway bars close to the 1LE setup. If you get coilovers I'd start with 600 lb/in on the front and get 175 lb/in in the rear.
I agree with Roy. I'm running "lots of spring rate" or, "not much spring rate" depending on use and the person being asked. But, I'll take my Koni DA's anytime for settling the car and making things happen.
I've got the Hypercoil springs. They aren't made any more, but they are *very* similiar to the G2 springs in rates, with the exception that the fronts are a bit stiffer. Lou raced them himself until he developed the G2's.
Those along with the G2 sways and Koni SA's have really nailed down my suspension (tho it can be a bit punishing on the road).
