Want to RR need advice
Brakes:
-Baer Eradispeed Rotors
-Hawk HPS Pads
Transmission:
-SPEC Stage 3 Clutch Kit
-SPEC Billet Flywheel
-01 Slave and Master Cylinder
-Pro5.0 shifter
-Lou's Quick Stick
-Skip-Shift Eliminator
Exhaust:
-Borla Adjustable Cat-Back
Suspension:
-Eibach Pro Kit Springs (front & rear)
-Bilstein Shocks (front & rear)
-Hotchkis Strut Tower Brace
-Hotchkis Pan-Hard bar
-Umi Sub Frame Connectors
-Umi Lower Control Arms
Induction:
-MTI Cold-air Induction Air Box
-Holley Power Shot Filter
-Granatelli Ported MAF
-SLP Straight Air Bellow
Ignition:
-Taylor Thundervolts 10.4mm Wires
Thanks in advance
I'm curious what I "should" change if anything?
Brakes:
-Hawk HPS Pads
Thanks in advance
Carbotech XP10s are a very good road racing pad. But are not good for the street.
-Pro5.0 shifter
-Lou's Quick Stick
STB is useless weight on the nose of the car
I do like my UMI parts, although I have yet to get any track time ... yet.
Deciding to go road racing is not something you "decide" ... you commit.
And the way you have modified your car, it will classify you into an extremely competitive group.
The best thing is to hook up with some local HPDE (High Performance Driver's Education) events. Get some seat time and take the driver out of the equation.
If you have never been on a road course, in stock form, your car is a lot better than your are as a driver. It's the simple truth.
You have to remember, when you are on a road course, your mistake can cause a LOT of other cars damage.
Drive smart.
Don't spend your money on the car now. Spend it on the track.
If you have an extra $3500, go to one Skip Barber, Bondurant, or one of the other schools. It may be the best money you spent. It could save you a lot of money on car damage your first couple of times on the track. The skills you learn will earn you a lot more respect when you get out on the track.
Toyo RA-1's and Michelin Pilot Sport Cup tires are R-compound tires you can drive on the street with (don't get caught in the rain with them). Mine lasted over 5K miles which is pretty good! If you can't afford a set of rims with dedicated road race tires then the above tires are about the next best choice. Bridestone S-03, BFG KD's and a few other tires are good choices as well for a real street radial but won't be as good as an R-compound or true slick.
If this is your first time slowly ramp up your entry/exit speed into corners and follow others ahead of you to figure out the "lines." I would suggest having an instructor go out with you as they can be a great help.
Thanks for all the help guys!!!!!
And I will tke exception to the use of R compounds on a car driven by a newb.
Street tires will give the driver several avenues of fedback. They will "skip" acroos the track when it pushes and they will "yell" when pushed ... both WAY before they give up altogether.
R compounds typically don't give a lot of feedback before they lose grip altogether.
Thunderhill and Infineon (Sears Point) including Laguna Seca will be the main tracks you run at. Thunderhill has a long front straight.... Infineon is pretty technical and then the legendary Laguna Seca course. Even amateur road racing can get pricey quickly. $179 for a single day not including gas, food, lodging, anything you break/wear and tear etc.
Start saving for brakes... you will need them. Maybe you should look at 1LE option brakes.
