went autox today
Any suggestionsfor the car, other than getting better behind the wheel. The thing that makes me think that I was limited by the car was my consistency of time. I know I can get better, but I was very consistent today. are there any street tires that are known to be really good for racing.
I have auto-x'ed my stock Formula for quite some time, and f-bodies are actually decent stock auto-x cars. If you look at the F-stock national results, F-bodies have won something like 17 of the last 20 years. If you are want to develop yourself as a driver, then don't mod the car. Do Konis, big front bar, alignment, and just drive it.
If you are having oversteer problems, be more gentle getting in the gas on corner exit. Is there anyone n your region who is fast in an F-stock car? Find someone good in an f-body to ride with and show you what it is like.
I went to the dragstrip last friday as well and couldn't launch better than a 2.3. before I got 2.2 easily. The tires are fun for drifting in parking lots though.
Also, where do the roadracing guys buy their springs..or do they special order them??
+ that way (with some sticky tires mounted on cheap stock wheels, or "salad shooters, etc.) you could stay in F Stock, develop your skills, and maybe even be competitive someday.
BTW; generally, once the spring rates get up above the 650-700# in. range, they are 2.5" diameter coilover setups. Now there might be some OEM size (5.5" dia.) uber high rate springs available from AFCO/Hyperco/Eibach, etc., but I'm not too sure on that. Mojave? Mitch? trackbird?
Seriously, get the Konis, big bar, alignment, and just drive. Staying on street tires will help you hone your skills. Work on going to as many events as possible. Evo schools are really good as well. Between runs go through the course in your head and keep track of where you make mistakes. Walk the course at least twice before your runs. Going fast at auto-x is hard, hard stuff (believe me, I've tried....). Fuzions are crap tires; it's no surprise you are slow. But, don't give up just yet, not on you or a stock f-body.
Mojave is trying to help you here by recommending you set the car up for F-stock and learn. You can build off of that setup if you later feel ESP or some other class is more suitable for what you want. Note that ESP is the last stop for a truly competitive streetable F-body.
A little piece of advice. Don't try and get tricky until you know what you're doing. We've all done it at some point, I did when I started and completely screwed myself class wise for years. And I was still losing.
Set the car up for F-stock. I'd be happy to help you through the process of setting up the car as well as warning you what's the car and what's not (I'm also teach folks to autox @ Evolution schools).
Queston about the alignment? When I go to firestone or wherever to get an alignment, will they align it to settings that I ask them to?? I purchased a lifetime alignment from them, so do you think they will do that??
But I agree that if the headers are not on the car, that you might want to wait. Because ESP is a lot more expensive than FS is (by a LOT) to get a competitive car. Some folks don't care, some say they don't--but they really hate losing. Some just don't pay attention to the rules and them complain when they find out they screwed themselves classing wise. And some, like me love the sport and the competition and would rather be able to compete on a very high level than install headers. YMMV, but you should think about your personality and how badly you want to win and how far you want to progress.
It really isn't hard to do if you can't find a shop that will do it. Sam can probably help with some pointers while he's processing your order.
Basically you want to max everything out. That only leaves the toe to set. Two jackstands, some common sense and attention to detail, a tape measure and some string will get that done. I have toe plates in the garage but don't use them that much.
What are my alignment specs? Don't know, don't care. I've got all that I can get so why worry?. Each side is reasonably close to the other so I just focus on the toe.
You could always have the shop check it for you when you're done and make further adjustments with that information (if necessary). The alignment check should be covered by your lifetime alignment purchase.
authority/credibility than the rest of us!!
