what did you do to your firebird today?
Old 07-20-2016, 04:05 PM
  #2881
jeffz's Avatar
I replaced my convertible top trim triangles with a flat piece of carbon fiber. Cut the patterns with a dreamy disc and sanded the edges/corners smooth. They fit flush a little closer than the OE's. Used 3M plastic emblem glue.
Old 07-29-2016, 08:31 AM
  #2882
michaelhawk's Avatar
A. Driver side low beam light was out, so I replaced the headlamp, both sides.
B. Adjusted Pass side headlight door to clear the hood and open
^ Now I can see at night again!
C. Parking brake dash light would NOT come on, made it difficult trying to pop the hatch with the yellow release button. After pulling the center console, I found the e-brake switch had a small blob of fuzz in between the 2 contacts, prevent the circuit to be closed. No doubt from the carpet. PITA to get to, Easy fix once inside.
D. Since the center console is removed, This was a good time to install PRO-Stick 5.0 shifter.
E. Replaced lumbar switch on pass seat, side trim panel. One switch was defective and wouldn't adjust the side support.
F. Since the pass seat is removed, This was a good time to install some extra padding in the lower seat cusion, to fit better my aftermarket seat covers.
Old 07-29-2016, 08:46 AM
  #2883
bleepster's Avatar
jacked up the rear end and put her on stands, removed differential cover, let the fluid run out into a foil turkey pan over night.
after work i will install TA performance cover and Mobile 1 synthetic 75w-90 with 4 oz GM slip additive
Old 07-29-2016, 09:41 AM
  #2884
hardtrailz's Avatar
Bought it some 18x8.5 c6 cup wheels
Old 07-31-2016, 01:38 AM
  #2885
Daniel Richards's Avatar
installed a new radiator, old one had sprung a leak in the plastic part of the radiator.
Old 08-03-2016, 07:21 AM
  #2886
bleepster's Avatar
this past weekend finished swapping out differential fluid and new cover. no leaks no noises +1
last night finally swapped out the rear hatch struts. replaced my deck last year with a TA hatch and my old struts were weak. now she stays up where she should.
getting her ready for a local car show this weekend. should be fun. suppose to be sunny and 82*. cant wait
Old 08-04-2016, 09:07 AM
  #2887
UMI's short stick installed along with Pro 5.0 shifter.
Damn that's a short throw - I think I like it.
Old 08-04-2016, 12:25 PM
  #2888
Nathan C's Avatar
Finally put the full coverage back on my 2002 Formula, washed it, got a synthetic oil change and new fuel filter, and am getting excited for the Pontiac Nationals this weekend in Norwalk, Ohio.
Old 08-04-2016, 12:27 PM
  #2889
hardtrailz's Avatar
Really wanted to take the new bird to Norwalk with the POSI guys from by me, but have a family reunion. Have fun up there.
Old 08-04-2016, 12:38 PM
  #2890
Nathan C's Avatar
This will by my 13 year going and I love it. Hope you can make it next year.
Old 08-06-2016, 12:48 AM
  #2891
ExtinctBird's Avatar
Had the alternator rebuilt. Runs brand new again!
Old 08-07-2016, 04:20 PM
  #2892
bleepster's Avatar
Yesterday entered local car show. Only got a few door prizes, nothing else. Had fun anyway.
Old 08-07-2016, 06:22 PM
  #2893
hardtrailz's Avatar
Ordered subframe connects
Old 08-10-2016, 05:40 AM
  #2894
Mrg60's Avatar
Sent my PCM to Frost for a tune
Old 08-12-2016, 07:09 PM
  #2895
Smoove's Avatar
Pulled the extension housing off
Old 08-13-2016, 09:40 PM
  #2896
toneloc60's Avatar
New rims and rubber.
Attached Thumbnails what did you do to your firebird today?-20160813_162213.jpg   what did you do to your firebird today?-20160813_143901.jpg
Old 08-17-2016, 09:52 AM
  #2897
Smoove's Avatar
Changed out the tail shaft extension housing bushing and re-installed
Old 08-21-2016, 12:38 AM
  #2898
usnfenix's Avatar
removed factory exhaust from manifolds to tips in prep for full 3" install with LT's. Notorious passenger side bolt put up a fight but was conquered in the end.
Old 08-23-2016, 06:35 AM
  #2899
SweeTbone's Avatar
So I went and had my AC charged up for the first time ever. Decided it'd be nice to have some cold air for the hot car show days. Take it to my friend at a dealership with all the proper machines to do it. Pressure test it and held so we put 2 lbs in and some dye. Literally 2 hours later it was blowing hot air again. Compressor just totally **** the bed and there is now green dye all over my steering rack boot and K-member. Sucks that $80 is down the drain but at least I know where to start.
Old 08-23-2016, 08:02 AM
  #2900
hardtrailz's Avatar
Slapped the UMI subframe connects on yesterday. Realized this morning that I need to go to the higher torque they said if I heard a thunk, cause I definitely heard it a few times on the crappy road to work. Will run them bolt in until I can get it the shop and have them welded.
Quick Reply: what did you do to your firebird today?
