Junk Pile 4.8 freshen up
Old 12-21-2017, 05:40 PM
A.R. Shale Targa's Avatar
Default Junk Pile 4.8 freshen up
Buddy says what the heck am I gonna do with this heap ?? Mock up block ??
Boat anchor ??
I’m like; hey let’s tear into it and see what’s good. Worst case scenario is a crankshaft known to take Four horse per cube......”Big Bang Theory”. Hot. Rod
So. Here she is. LMFAO
He pulled one head and quit. Lol
Decided to snap some shots bout twenty minutes into the mess
YUMMY
Old 12-21-2017, 05:49 PM
Received 3,507 Likes on 2,162 Posts
Have mercy miss Percy....
Old 12-21-2017, 06:43 PM
LS1Tech Premium Sponsor
tech@WS6store's Avatar
Build that 4.8 into a 5.1l and have some fun
Old 12-21-2017, 07:18 PM
cookseyb's Avatar
Or a 5.7 to clean up the cylinder walls..
Old 12-21-2017, 08:25 PM
Cant build a 4.8 into a 5.7 without crank and rods.
5.1 is a 3.90X bore 4.8 crank n rods.
Old 12-21-2017, 08:27 PM
KCS
KCS's Avatar
Sshhhhhhiiiiieeeeeeeeettttttt, dingle ball hone it and let her eat!!!
Old 12-21-2017, 10:28 PM
Both great ideas !!!!
Buddy says. “Hey those rings must have sealed great cuz four cylinders held water really well”.
My guess is after I stone hone these bitches by hand and dingle ball them, a new set of rings should have the proper end gaps for about 20 pounds of boost.
Prolly weld up the head deck notches, cut em’ thirty, lap the valves and assemble with new seals and blue springs
Got a 99’ LS1 Cam, pop an LS2 chain on and shim the ported oil pump
But I do kinda like the 3.900” bore with a 3.268” arm too. We shall see
It’s his engine. My time. Just keepin busy and outta trouble
Old 12-21-2017, 10:31 PM
Why even bother welding them? we have notched mls head gaskets.
I doubt that will clean up with a hone. Ive seen blocks that looked better that needed .020 or more.
The 327 was only impressive because it had a larger bore. Otherwise it would have been no better than a blue 289.
Old 12-21-2017, 10:40 PM
Although i prefer CID, i understand the allure of short strokes. I mean that's what got me through high school...lol
Im only building the 333 because i have a spare 4.8 crank and rods and a spare ls2 block that needed a .030 overbore to clean up a liner that looked better than yours. So kachow, 333.
Still a pretty odd combo but a great platform for testing a few new cams also. Win/win really
Old 12-22-2017, 11:52 AM
2.800" stroke versus 3.25"
That's a killer boost setup there......
Old 12-22-2017, 11:57 AM
You missed my point. If the 327 didnt have a larger bore with the short stroke it would be no better than a ford small block. It was a jab at ford also
Old 12-22-2017, 11:59 AM
AnotherWs6's Avatar
I vote scrap metal.
Old 12-22-2017, 12:02 PM
Either way you do it, machine the rods for floating pins. Your friend will be happy they did.
Old 12-22-2017, 02:02 PM
Guess I didn’t understand “larger bore”. Than what ??
Both the 289 blue oval and the 327 Chevy had four inch bores
Just the stroke varied by .450”
No harm though.
Old 12-22-2017, 02:43 PM
This thing is Taco Bell out house NASTY
This represents over two hours of elbow grease last night.
Nasty; YES. cleaner than it was; HELL YES
Old 12-22-2017, 02:53 PM
Karlw's Avatar
Bottom end looks far better than I expected! I bet there was a lot of puke in that oil pan.
Old 12-22-2017, 03:03 PM
Youre thinking too literal about what i said lol
Old 12-22-2017, 03:28 PM
00pooterSS's Avatar
Dude, send it! A little wd40 and it'll be good to go!
Old 12-22-2017, 05:16 PM
Well.......she's tight. I was able to step on the breaker bar to loosen the harmonic balancer bolt...
Old 12-22-2017, 05:59 PM
00pooterSS's Avatar
LOL that's bad
Quick Reply: Junk Pile 4.8 freshen up
