Clip on line
Old 03-09-2018, 08:13 PM
Irocwagon's Avatar
Default Clip on line
00z28 t56
the clip that holds the line in the side of the transmission from the master cylinder fell off and the line came out resulting in a dead pedal. Trans was just put in a lil over a year ago. Is there a way to buy just that clip and can it be put back in without dropping the tranny???
Old 03-11-2018, 07:05 AM
stevieturbo's Avatar
post a picture of exactly what you're describing.
Are you referring to the quick disconnect part or something else ?
Old 03-12-2018, 08:04 AM
Irocwagon's Avatar
It’s deffinetely a quick disconnect, it’s raining here but will try to get a pic. I’m not a tranny guy, I did also see a crack in my bellhousing, I’m holing that’s not the cause
Old 03-14-2018, 11:46 AM
Irocwagon's Avatar
That gap seems to get larger as it goes down. Normal?
I wonder if it was cracked during install
The clip that holds this line in
No bolts in lower bell housing to tranny
Old 03-14-2018, 12:12 PM
Irocwagon's Avatar
Old 03-14-2018, 12:18 PM
Irocwagon's Avatar
This little black clip. How can I get Just that part was the initial question. The other was loose and fell off
Old 03-14-2018, 12:30 PM
ss.slp.ls1's Avatar
I would take it to the shop that installed your clutch. That gap should not be getting larger as it goes down. The transmission should be flush with the bell housing. Also in one of your pictures I can see that three bolts that hold the transmission to the bell housing are missing. It seems like they may have been the one's who cracked your bell housing also. Looks like a bad installation all around. Where did you go?
Old 03-14-2018, 02:22 PM
That bellhousing is fucked, and the lower portion is pulled away partly because of the BH being fucked...but because all the bolts are missing lol.
So yes that is a large crack.
It also looks like both the metal retaining clip inside the slave quick release is missing, as well as the plastic collar on the car side that is used to release it.
No idea if you can buy the metal bit separately, but there's bound to be loads of guys with old ones knocking about from old slaves.
Monster and no doubt GM will sell the plastic collar for the hose side.
http://monsterclutches.com/1998-2002...aulic-retainer
Old 03-16-2018, 07:31 AM
Irocwagon's Avatar
they didnt just just do the clutch, they put the complete tranny in, no lower bolts at all. Asking what they are gonna do about it now.
Old 03-16-2018, 08:57 AM
bleepster's Avatar
keep us posted. hopefully they stand behind their work
Old 03-16-2018, 01:40 PM
Very shoddy work indeed !! Lucky it was spotted or it could have been a huge mess !
Old 03-17-2018, 09:26 AM
Irocwagon's Avatar
I’m in sc, and if this shop doesn’t do me any justice, I will be posting the name, invoice in the forums. First thing I need is a damn bellhousing.
Old 03-17-2018, 01:43 PM
Surely they should be buying one ?
Bound to be plenty about or they can get a new one.
Old 03-28-2018, 08:38 PM
Irocwagon's Avatar
so I would need this retainer and still need that u shaped clip?
Old 03-29-2018, 11:05 AM
You need the plastic sleeve pictured above/monster in order to disconnect the quick release setup.
You need this metal part inside the QD fitting...in order for it to actually lock together.
http://www.pro-touring.com/attachmen...1&d=1325445469
