And So It Begins!
Make sure you "calibrate" that lokar dipstick. They are notorious for being a quart or two off if you just install out of the box
Measure a stock one and set the lokar to the same extension length when fully seated. Also make sure you KNOW what trans and pan capacity your dealing with ,, there are a handful of different stock TH400 pans.. Each holds +- a quart or two different.
