Swapping SBC into LT1 F car
#92
what motor mounts are you guys running...i didnt even check to see if the stock mounts would bolt up to my sbc i have im about to use a motor plate but **** this seems way easier...are they just stock mounts from an lt1?
#95
ok so my motor mounts were about 6 inches away from even being close to working so i had to go motor plate which im ok with should stiffen up the car and really bring out the raddles..here are some pics of it so far got the car 4 days ago with 3.8 and started buying parts from there ....the little **** just keeps adding up its ridiculous.
im hoping i can get it to put down around 300 on motor which sucks compared to the little bit of work i did in my ls1 to get 420 to the wheels....but im going to get the car down to around 3000 lbs with me in it hopefully... and the bottle...
![](http://i24.photobucket.com/albums/c9/redls1/camaroproject006.jpg)
![](http://i24.photobucket.com/albums/c9/redls1/camaroproject007.jpg)
#96
ok I have started making motor and trans mission mounts for the 3rd gen motor in the F bodys and is interested will sell for 150 for set.
I put a 1969 327 in my 99 camaro and man its a beast haha
#98
zones do u think all that was worth it? 311 hp 350 torque?
I would think u could have rebuilt the LT1 with some better parts and got those #s and not have to change anything, chassis, connectors, etc.
#99
Well, for one, it was a vrry easy swap, for two, i had everything laying around to do the swap and i got to eliminate the piece of **** optispark, THAT in itself was so worth it it made me tear up. You have to remember, this was on a mustang dyno, i am using the smallest vortec intake available and i have the shitty pace setter shortys on it, lets not forget the 102* weather, AND it was even hotter in the shop, it literally felt GREAT to step back outside. I even had 89 octane in the tank, it runs way better on 93. Lets not forget...i dont need a lap top nor a individual to tune my car, everything about it made it worthy. Not to mention i like being different.
The only thing i had to buy was a couple gaskets and a set of valve springs.
I will post the new results when i get the bigger intake and full lengths. A dynojet would have put closer to 350 HP down.
