Parts Suggestions for my Build. Help!
Okay so here is what I am building.
I have a Chevy 350 .030 4 bolt main block
I have a set of 062 vortec heads. 64cc
I am trying to make something in the 350-400 range but I want something that will run on 87 octane what do you guys think? I was looking at a kit such as this:
http://www.summitracing.com/parts/FE...0/?image=large
It says 9.35:1 with 64cc head. Will that burn 87 adequately?
Its going in a daily driver jeep with a SM465 chevy heavy duty trans.
Any suggestions are appreciated. Thanks
Brian
Brian
It's gonna be hard to build a 355 to run on pump gas and also make that kind of power. Those vortec heads are pretty good heads up to a certain point. I have a 350 that has right around your compression and it hates 87 octane. To have a 350 making that power you're more than likely going to have to run good gas and it's probably not going to be a motor you will want to drive daily. 285-315 hp would probably be a better figure to shoot for. Good luck
What about if I added a thicker head gasket would that lower the compression enough and not sacrifice too much power?
THanks Guys I appreciate your input!
Yes you will more than likely need to run premium depending on compression. To get 350 to 400 hp you will probably need around 9.5:1 to 10:1 depending on cam, heads, etc. If you really want a motor with that much power to drive every day you might look into a LS motor (LS1, LS2, 5.3, etc). And to answer your question yes a thicker head gasket will lower your compression and so will a larger duration cam, but you need to match all your parts to get the most out of your motor. 400 hp out of a daily driven first gen small block might not be the best idea but good luck with whatever you do.
well what pistons are you running.? 64 cc are higher compression heads with the right pistons but can be very streetable also. 300-325 hp sounds pretty good and I think you would like that much better for your application. for todays unleaded gas, you will probably want to look in the 8.5:1 or 8.75:1 range to run 87 and have good advance without your valves rattling. your vortec heads, about a 268 duration cam, dual plane intake, headers, and good HEI should have you running pretty well. hope this helps good luck
In-Zane Moderator
Well, i just built a 355 last week, it has:
.030 flat top 4v reliefs TRW forged
Stock rods with ARP bolts resized
stock crank balanced
Stock vortec 062s with bigger springs for lift with guides cut, studded with guide plates
performer intake
OE roller lifters
Elgin cam with 230/230 @.050 with .480/.480 lift on 108 LSA
1.5 int and 1.6 exh crower roller rockers
It needs a stall, but on a roll in the 86 trans am it is in with 3.07 gears and 700R4, it pulled my 95 Z28 on the big end with no trouble with 311 RWHP and 350 TQ from the 95 Z, T56 and 3.23 gears.
Not bad, makes about 9.7 to 1 comp, runs on 89 octane.
performer intake
OE roller lifters
