t56 retrofit to bbc, What to do?
I have a 2001 t56 from a ls trans am, I am installing it in a 55 chev behind a bbc. when i test fit trans to engine my input shaft appears to be about 1/8 to 3/16" to long, is there a spacer that would work between engine & bell housing? or perhaps a different bell housing? I would like to retain the hydraulic release bearing if possible.
what is the best way to do this install?
what is needed to move the shifter to the forward position?
can the spedo be changed to gear drive internaly?
Bczee is right. LT1 T56 is the best way to go. I actually have on with the bellhousing and all laying around if your interested. As for changing the shifter location, that requires changing alot of the internals if I'm not mistaken.
You can move the shifter forward to the inspection cover, but you have to pull the case apart to repin the shaft. I'm trying to remember who has a kit if you don't want to source the parts yourself. I think it was Kiesler.
Mcleod is the one that markets the Shifter Relocation kit. I had looked into them before. but the added cost of having to disassemble the trans was not something I felt I wanted to get into.
You could sell or trade your LS1 T56 for a LT1 trans.. is the option of not doing any of the above.
thanks for the feedback, I had to re-register to get back in, not sure whats up?
I am prepared to disassemble the trans.to relocate the shifter forward,and if the best solution is to replace the input shaft i can do this at the same time.
Is it correct that the LS1 T56 trans is stronger than the LT1 version?
The LT1 style clutch is a pull type clutch with a fork. The LS1 is a std. push type clutch that slides along the input shaft. I don't know of anything that was done to the LS1 T56 versus the LT1 that would make it stronger, but I'm no expert.
As to your question on the strength, from what I remember, only the 93 model T56s with the different gearsets was weaker. If memory serves, the standard T56 was a MM6 gearset, which was all 94-02 F-body T56 trannys, which the one I have would be, whereas the 93 had 2 sets, the M28, and M29, both of which are different than the MM6.
As for mine, its all there; tranny, shifter, bellhousing, and I thinking I even have stock flywheel (problem there is it would be the small bolt pattern I believe, and depending on what your running, you would need a large/old style bolt patter since they went to a smaller bolt pattern in the mid/late 80s on all SBs). I don't have a clutch for it, or the hydraulics, but that should be replaced when it goes in anyway, tbh. I'm phasing out all my GENI/II stuff, so if you were interested, I'd be willing to do some kind of trade perhaps since I could use a spare LS1 T56. Never hurt to have an extra, right?
Actually, if I'm not mistaken, the spline counts are actually different, but I could be mistaken.
