This is not a classifieds forum. Post ALL sales in here.
#61
Check out my LSX setup that i would like to trade for a sbc or bbc setup.
https://ls1tech.com/forums/parts-wanted/742956-wtt-6-0l-t-56-sbc-bbc.html
#62
Engine has Dart block. Cola crank. Eagle L19 H beams. Ross pistons with Hellfire rings. TFS 18 degree heads with titanium 2.18, 1.65 valves. Yellow Terra pedestal mount offset rockers with Comp lifters and Comp cam. Bowtie intake manifold. Engine fresh from builder with just one dyno pull. Made 775hp and one full pass. This is a nitrious motor. Asking $7500. Engine is at builders in South Carolina.
Also available custom 4150 style 1375CFM Carb. Wilson nitrious plate and Moroso Vacumme pump. email for pricing
Drag race Power Glide. 9310 Gear set from coan. 9 clutch drum. TCI Pro brake Only thing stock is the case. Ultra bell. Asking $2800
TCI Converter for engine 8 inch nitrious custom asking $1000 paid $1300
The above engine and transmission combination went 8.30's @ over 165mph consistantly at 3200lbs in the 1/4 mile
Package price will be cheaper. Call me for information 416 931 3203
#63
LS1Tech Premium Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I have a set of brand new Lemons step headers for the 4th gen Camaro or Firebird Chassis. They are for a SBC with 18 degree heads with the Stahl spread port bolt pattern. They go from 2.0" to 2 1/8" and have 4.0" collectors. The primaries already have EGT bungs installed and the collectors have 02 Bungs installed. I sent them out and had them Jet Hot coated the high temp Black. I have $1450.00 in the headers alone not including the coating will take $1000.00 + shipping for them. If you have any questions just shoot me an E-mail.
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Lee Spicher
(813)986-9302
#64
i know not many will work with an fbody, but i figured i might as well share what i have..
here they are, they must go asap....
- ‘72 350 014 Short block, Cloyes double roller timing chain (5k miles), 5k on pistons and rings. Needs new bearings, and cam – 350.00
- Polished Powdered Metal connecting rods – 125.00
- ‘71 350 336x heads, little port work, Z28 springs, needs valve guides – 120.00
- Brand new Hurst Quarter Stick shifter still in box. Set up for Powerglide, will work with other 3spd auto transmissions – 140.00
- 70-72 Chevelle Driver side quarter panel, New. - 125.00
- 70-72 Chevelle stock flat hood. In lacquer primer. 75.00
- 71-72 Chevelle front bumper, should be re-chromed – 25.00
- (2) 71-72 Chevelle Rear Bumper, in decent condition, straight – 40.00 each
- 70-72 Chevelle rocker panel molding, good shape – 40.00
- 71 Chevelle headlight buckets – 50.00 pair.
- 68-72 Chevelle upper and lower rear control arms. Need new bushings – 40.00
- 68-72 Chevelle Boxed Upper and lower control arms with Poly Urethane bushings – 130.00
- 70-72 Chevelle Custom Center Consol. Vinyl and stainless steel – 120.00
- (2) 15x10 Cragar S/S rims, chrome in okay shape, spokes painted black – 40.00
- (2) 15x6 Cragar S/S rims, chrome okay shape, spokes painted black, with tires – 60.00
- (2) 14x6 Cragar S/S rims, painted silver – 25.00
All prices are negotiable, and all items are sold as is. i do have pictures also.
can contact me at speeddemon88@rcn.com
aaron
aaron
#66
We have a 383 short block for sale complete and ready to ship. It has A.R.P. main bolts, fresh align hone, eagle 4340 forged crank, H-beam rods w/ A.R.P. rod bolts, JE pistons-flat tops with two valve relief’s at zero deck, torque plate honed, clevite main and rod bearings, balanced and blue printed, comes with a m55 HV oil pump, oil pan, timing cover, timing set and a choice of two different cams. It's has a one piece rear main seal.
The buyer pays for shipping. $2500.00.
If you have any questions please call.
Thank-you,
Harold
Port Pros LLC
512-257-0222
Thank-you,
Harold
Port Pros LLC
512-257-0222
#70
Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 260/272, Lift .484/.515, Chevy, Big Block, Kit $150.00 Bob
http://www.exoticperformanceplus.com...html?item=1333
#71
I have a rotating asembly for a 350 SBC for 250.00 Includes, crank, rods, flattops, (Not sure if they are forged or not) Every thing seems to be in good shape. I'm building a 406 and dont need it anymore. I got it from a buddy of mines that said the motor was built, he didnt know when or to what specs. If your interested PM me or call me 334-354-9332. Thanks alot.
Nick
Price is up for offers by the way.
Nick
#72
I wanted to check on here before I went to ebay or racing junk or something. The motor is not out yet and won't be till after New Years. I just want to see if any of you are interested. Heres some info:
1996 LT1 with about 90,000 miles (I think its about 86 or a little less, I just call it 90,000). There is a CC306 by Comp Cams, Cloyes double roller TC, CSI electric water pump in stock housing, crane cams hydralic roller lifters, harden push rods, crane cams double beehive springs, GM LT1 conversion manifold (for carb), taylor pro race 8mm plug wires, lower alt. bracket, msd 85551 pro-billet dizzy, summit coil.
I think thats about it. I'm getting ready for a big block and dont want another motor sitting around the garage, cluttering up space. I also might get rid of the tranny but I want to swap it for a working one (its a T56, maybe about 20,000 miles on new clutch).
Let me know if your intested. PM preferred.
#73
http://dallas.craigslist.org/pts/515642827.html
Will trade for a nice late model LS motor or late model 12bolt or 9in rear as partial trade...tired of this project...time to focus on the late model![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Let me know if anyone is interested.
#75
http://www.exoticperformanceplus.com...l?category=250
I lowered the price of many intake manifolds even further. Check it out, there are a lot of great deals to be had! Bob
#76
http://www.exoticperformanceplus.com...html?item=1393
Awesome 3 piece intake. $550 to anyone on here, check out what other places are selling this for, I'm hundreds less! Bob
![](http://www.exoticperformanceplus.com/performance_parts/images/248448809.jpg)
Price dropped to $500.00, anyone? Bob
#77
Selling my 468 BBC setup
Still need to pull the short block, block is at max bore and some cylinders have some very light gouging, nothing real serious, car does not smoke or burn oil.
Stock bottom end with forged domed pistons (TRW L2349), looks like a two bolt main block, comes with a double rollder timing chain with no excessive slak in it at all. Can sell a factory belt driven water pump with it with a fan for it. Local pick up on this would be very nice. Once I puill the short block apart I will post more pictures.
GMPP ALUMINUM C port heads that look fine and are at least port matched on the intake side. COULD ship these. Can sell these with the short block and with that the compression is 10.X.1. One intake valve stim is mushroomed/or damaged a tad because of a rocker going loose but should still be usable but if not its a cheap fix. Pictures below.
All but 1 aluminum Earson 1.7 rockers.
One of them went bad when the polly lock split in two.
Barry Grant 850 carb that has been ported to flow 1,040 CFM by Barry Grant Carbs. BG is etched into the carb to prove this is what it is. This is a killer speeler carb, looks just like an 850.
Have some 1 3/4 or whatever headers (looks like Hooker Super Comps) that fit third gens with BBC swaps and have been modified to clear everything. I would keep them but they are to small for the new motor. A little rusty but still good.
Also have a factory looking starter that fired up a 10.X.1 compression BBC no problem. I would still use it but my new motor will laugh at it.
Have a old MSD SBC/BBC mechanical advance distributor with a female pul style cam that Ill sell cheap. I can sell the brand new Moroso wires I have for it with it.
Also can sell the solid flat tapet lifters that are still in great shape and after I measure them can sell the push rods cheap but one will need replaced (loose rocker issue again)
May or may not reuse the Earson Aluminum 1.7 rockers, if you are interested let me know.
Here are some pictures
http://s275.photobucket.com/albums/j...vids%20Camaro/
Ignition system
All parts work great, only selling because I am upgrading for the new motor.
MSD mechanical advance distributor SBC/BBC PN 8461 comes with new Moroso wires and female cap and rotor.
MSD ignition box PN 6400 serial number 47411
MSD spark retard box PN 8980
MSD Blaster 2 coil PN 8203
Make an offer on everything.
Also have some nice 4th gen red and black floor mats with Z-28 in red and a brand new in the bock 96-97 LT1 O2 sensor (not the emmisions ones, the front ones)
Will add more when I figure out what I will keep and ditch.
Ignition system
#79
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
