Okay old school tech question (SBC)
Here we go I'm building a 383ci fuelie. I got the short block from the machine shop and it's got the wrong pistons. I ordered a 3.75" stroke with 6" rods and "inverted dome" SRP pistons well I got flat tops instead. The heads are "supposed" to be 64cc buut they are more like 66cc-67cc then I CC'd the cylinder with the piston at TDC and got 14cc (the piston has 5cc valve reliefs) so here is the question whats my compression gonna be? I figure I'm gonna run a .035 to .040 compressed height head gasket.
The problem/question is do I go by the cc'd volume of the cylinder or do I go by the advertised -5cc's for the valve reliefs? The numbers are substantially different the JE chart figures around 10.5 to 1 but the calculator says about the same figuring on -5cc but figure on the -14cc cylinder volume it says about 9.5 to 1.
So what is it?
So what is it?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Go by measured values. Reason you got 14cc is that the piston is not flush with the block deck unless it has been zero decked. So piston is slightly down in the bore (deck height) and that adds volume to measurement. Check out this calculator:
http://www.turbofast.com.au/Tfcomp.html
I need to check the deck height in the morning but it looks pretty damn close to zero I think most of that volume is coming from the ring land. But really I wonder if the piston mfg. counts that when they claim -5cc's.
So what is it?![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
So what is it?
So what is it?
Well what has happened in the last few days....
1) Had the heads gone through the valve job was adequate but sloppy (mass production) Edelbrock RPM E-tecs
2) Before the valve job the "64cc" chambers were actually 67cc after the valves sunk a little bit and every thing was at equal height the chambers are now 69cc.
3) Talked to JE pistons and told the guy what I have and he said I would have 10.5-1 with 68cc so now that I have 69cc I'm golden. Also after the shop was done with the heads we figured it out and they came to the same conclusion.
From every thing I've ever read or heard 10.5-1 is about the max with ALUMINUM heads to run premium on the street. I should be fine.
Also I'll prolly make jus shy of 500hp at the flywheel
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Actually u can go 11 to 11.5 to 1 with aluminum heads, on 93 thou! 10.5 is about the max with steel heads! Iam glad u got everything sorted out! Yes u should be runnin around 10.5 to 1! Depending on what head gaskets u run!
Yea thats pretty much what I've figured out the last few days. The end result id I'll prolly be between 10-10.5-1 depending on head gasket.
Thanks for all the input guys.
