Bad cam? Low compression?
and the engine was shut down with that particular piston at tdc.....
there would be no air to compress...
less air in=less air to compress....
no air out=egr effect=lower compression
it is affected by crankshaft stroke. which affects piston speed
and it is affected by intake valve closing point @.050 abdc
in other words yes! static compression is the same (mathmatical compression)
dynamic compression(which is while the engine is running) does change due to cam design.
if the valve closes late the dcr will be low
if the valve closes early the dcr will be higher
i dont know how much it would take for a cam lobe to effect the measured pressure? but if it is worn it will not allow as much air in the engine i do know that
FYI- U.T.I drivibality classes teach a worn cam lobe will cause low compression along with worn rings, bent pushrod,broken rocker arms, valve guides, seats, gaskets, bla bla bla......
