How to tell if SS hood is GM original?
Hey guys,
I am buying an SS hood and I am just wondering, what do I look for to make sure its a GM original SS hood?
Thanks,
Lane
Thanks,
Lane
Originally Posted by 383lt1
SLp sells a true original i know that for a fact meat a guy that works for them the get thiers from GM direct and sell them to us so check them and no need to worry about knock offs
What? Does that make any sense?
On mine under the hood latch or the hold down there is a cheaply engraved ss number.
Originally Posted by lrk322
Hey guys,
Who are you buying the hood from?
A person on here with an camaro SS is selling an SS hood, I just want to make sure if I meet someone and can't actually throw the hood on the car, that I can look for some part number or something and be absolutely sure that its a factory original.
So behind the hood latch I can just look for the part # you listed and I will know for sure?
I have a original GM still in the box. The sticker on the box says pick weight is 80 lbs. I'am guessing the box weights around 10 lbs. So if you weight it, a GM hood would be around 70 lbs. Hope this helps - don't know any other way except to compare two side-by-side.
Originally Posted by '02 SLP#686
80lbs??? Mine was so friggin light when it came off I couldn't believe it was anywhere near 70lbs???
Originally Posted by Duffster
So this would probably be an authentic SS hood? Found this under the passenger support mount. . .
![](http://i10.photobucket.com/albums/a101/Duffster-01Z/SS%20Hood/ssidnumber.jpg)
