Evans Water pump GP
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Evans Cooling Systems Inc has just released a new highflow LS1-6 water pump. The billet coolant pump and pulley flows over 20% more than stock and changes the cooling pattern for a more even cooling. The pump increases cooling efficiency in modified LS1 Corvettes, Camano’s and LS1 based motors. Evans has changed the design of the OEM pump casting and includes a billet pulley hub and heavy duty 3/4" shat bearing assembly. It also includes a 3.8" OD 8 vane scrolled impeller to reduce parasitic horsepower loss at high RPM. A new serpentine belt is required.
pics
https://ls1tech.com/forums/attachmen...achmentid=3364
https://ls1tech.com/forums/attachmen...achmentid=3363
Evans complete new water pump with billet pulley $469.95 for Corvettes
Evans complete new water pump with billet pulley $469.95 for F-Bodies
Brand new casting no core retail $469.99 GP $395.00 NO core required
Used casting remachined retail $399.99 GP $340.00 +$125 core charge
Add $125 for ceramic thermal coating-for extra heat dissipation and a little bling
Evans super flow 160* T-Stat $49.95 reqiered with purchase stock does not flow enough
Goodyear serpentine belt $49.95
Evans NPG coolant $22.50 a gallon
Evans NPG+ coolant $22.50 a gallon
Also Evans new NPG R race coolant in stock $19.50 a gallon
Or buy by the case(4) and save
pics
It cools Way better than the other pump. Ask Meziere there pump flows about 20% less than stock(for race use only not intended to keep a street car cool) Evans pump flows 20% more than stock with improved flow around the cylinders where the stock one lacks. Helps in keeping control of the heat created by high HP.
Nate
Nate
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
If you have the ability to send in your water pump (core) to be machined - then you're actually saving $55 at $340.
If you can't do that and need to buy the pump outright then it's $395
Nate explained that it is the same machining procedure to either casting (the Evans casting is identical to the stock casting) They just offer a version with a new casting for those who can't afford to be without their WP for a while.
Quik has it right. That and some with all out motors don`t want to reuse the old housing.
I think I have enough for this to go through. I just need everyone interested to call with the order. And I can get it rolling.
Another note the Evans T-stat is requiered for the extra flow of the new pump. The stock t-stat does not flow enough. $49.95 with purchase.
Thanks for the orders Nate
I just ordered mine - ceramic coated w/stat! So gentlemen - get out those credit cards
Thanx for the GP Nate and please don't forget to check on the correct belt size to go with my ASP UD Pulley and the stat issue.
-Jay-
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
-Jay-
Jammer most have gone out I don`t know if you recieved them yet they are coming straight from Evans.
Jay get us some pics of that thing I haven`t seen the coated one yet.
Nate
Nate
