PBT's LS1/LT1 Drilled/Slotted Rotors w/Pads BLOW OUT!!! Starting at $189+Shipping
Happy New Year everyone! It's time for me to go back to work so I thought I'd start the new year off with something special...
After going through my invintory I found 8 sets of drilled and slotted LS1 (98-02) rotors and 3 sets for the LT1 guys (93-97). These are the same rotors I sell every day but I'm currently machining a slightly different design so I decided to promote these first.
Heres the deal:
(4) rotors, front and rear, drilled, slotted and plated for $119.00
(4) rotors, front and rear, drilled, slotted and plated with a full set of OEQuality Friction's semi metalic severe duty brake pads for $189.00 plus shipping. This will set you up with a high quality brake job at an unbelieveable price!
Or, if you'd like to take it to the next level:
(4) rotors, front and rear, drilled, slotted and plated with a full set of Akebono ProAct Ceramic pads for $249.00 plus shipping. (Please note that if your rotors arrive without pads, it will be noted with your shipment and you can expect them to arrive within a few days. I'm currently low on stock of Ake's and I'm expecting replacements next week)
Shipping costs are as follows:
West of the Mississippi $25.00 flat, East of the Ol' Miss... The Ol' Man... $45.00 flat.
Thanks for your support everyone! As always, I'm most easily reached by cell or PM. Let me know!
Harry
Heres the deal:
Harry
Can you use these with the stock oem pads? My car is still in the shop after I got into a little fender bender before fall finals, and this maybe a better investment than the manta stripe I was going for
The zinc plating's purpose is to prevent corrosion. "Never" is a very strong word but, for all intents and purposes, you can count on them not rusting. Just remember that the pads will immediately remove the plating from the face of the rotor and if the car sits outside for long periods of time surface rust will form only on that part of the rotor until the next time you apply the brakes. The hat and the vanes, however, will remain rust free for a very, very long time.
Harry
Harry
The cross drilled rotors dissipate heat more efficiently than plain rotors. Independent tests have shown temperatures up to 25% cooler for cross drilled rotors vs standard. Cooler temps keep rotors from warping and brakes from fading!
Harry
