heads up display in a 00 Camaro SS?
Any write ups, articles or info that someone could share?
This is the only related thread I could find, which is pretty much nothing LOL. At least I found out not having a HUD windshield will work just fine.
https://ls1tech.com/forums/corvette-...p-display.html
I thought of something similar to HUD and my idea was to use a pocket projector to project the speedometer onto the windshield, tint a part of windshield if need be it.
The brain of this could be a car computer that reads info from the OBDII port, projects info using the projector.
If a car computer isn't really an option, an Iphone or Itouch can do the job too.
https://ls1tech.com/forums/stereo-el...-possible.html
(There are more links in there too)
Alright so the average "easy" so called option seems to be the defi. I don't think it would be a bad deal as long as I could conceal it. I don't want that bulky *** thing in my sight.
http://www.defi-shop.com/product/con...ncept_top.html
http://www.defi-shop.com/product/bas...s_install.html
All the links to topics on HUD systems on our car.
https://ls1tech.com/forums/appearanc...hud-fbody.html
Lingenfelter I guess sells them.
https://ls1tech.com/forums/stereo-el...splay-hud.html
https://ls1tech.com/forums/appearanc...ay-f-body.html
https://ls1tech.com/forums/stereo-el...d-camaros.html
https://ls1tech.com/forums/appearanc...ould-take.html
I had a 1996 bonneville HUD that I was going to adapt to my WS6, but I would have had to cut out a place 7" by 8" by 3" deep to hide the projector.
It did display on the windshield, but not nearly as good as my 92 bonneville or 2000 grand prix OEM units did.
Ryan
http://www.defi-shop.com/index.htm
http://www.exoticvette.com/HUD.htm
http://www.ls1.com/forums/showthread.php?t=70946
So there is a few that I’ve found. It looks like using the gm hud from the Grand Prix isn’t as easy as first thought. The defi may be an eye sore. Not sure of any other ideas.
This one that black n sleek posted might not be too bad if you just have the screen protruding out of the middle dash vent? Meaning all you see is that screen? The idea is not to see anything but the projection tho, no tacky HUD box please.
The primary concern is space to mount it since there is no room for an OEM HUD assembly (either Grand Prix, Bonneville, or Corvette) in the cowl area without some cutting. The secondary concern is making it look good. You will have to hack up your fragile ABS dashboard panel and make it still look good. Electrical is not too much of an issue if you can tap into power, ground, and VSS (4000PPM).
