C6Z vs. 500hp Turbo S2k (vid)
#441
Under the Magnuson-Mass warranty act they should have to prove that your tune directly resulted in the failure of the transmission. So unless you raised your redline significantly higher or something, the tune should not matter. Sounds like you got screwed over by your dealer, sorry to hear about that.
Good luck fighting that.
#444
Someone is definitely on a high horse around here
You love calling people out about their post count. Well this is the street race section, so how about you post up a race video of your car so we can all tell you how awesome you are? Post your own race or get fucked and stop being the biggest douche on this site.
Lol at the BMW pics. To each their own. I will say that the Audi line trumps BMW in the looks department.
#446
#449
#455
NOOBINATOR...
Love the name BTW....But FERRARI/LAMBO..Not even mentioned in the same sentance...The Viper/NSX are both bonafied bottome of the barrel exotics..Theve got a just barely pricey enough MSRP of 83K and 87K (starting from the early 2000's mind you) respectively for the base models...Theve got the look at me Im somthing special looks ...Theve got the 1 off thing going for them. One has the largest production engine available for sale and the other was desighned by a famous F1 driver from the ground up and one of the first all aluminum vehicles built...But more importantly they both are VERY rare and in 15-20 year production runs only 20-25K were produced for each car...
The GTR has the price point at 82K covered wich is just enough to not be affordable to the average person..The GTR dosent have the look at me Im somthing special look. It is HUGE and looks like a randon G35...But this is subjective so it could still pass as a bottom of the barrel exotic at this point. As far as the 1 off thing it has nothing going for it. AWD is kool but porshe was doing it LOOOOONG before hand..
But the biggest factor is the production numbers This is were I dont think the GTR can make it into the bottom of the barrel exotic catergory. There seems to be a lot of them. Ive seen more GTR's in the past 18 months than I have Vipers in my life...
So basically before you can even compare to an exotic lambo.ferrari..You have to atleaste be in a lower level exotic...Cant say the GTR is one
#456
Again..for a car that isnt hand built...Like the Viper/nsx..Dosent even have its own assembly plant and is built right next to g37's on the same assembly line..and at 12000 per year produced. It is NOT a lower end exotic The Z06 at only 7K units made per year and its hand built LS7 actually has a stronger case for bottom of the barrel exotic than the GTR..if it wernt for those pesky 30K base C6's made per year it would be a sure thing...
Exotics have their own assemnly plants///are hand built in some capacity or completely ///and are limited production..1k per year..2 k per year..maybe 5-7 k per year..
But at 12k per year a GTR is a mustang of the 80-100K car world....
Just try to remember that the next time you mention Ferrari or Lambo.....
2009 Nissan GT-R: From Steel to Supercar Feature Video
Feature
2009 Nissan GT-R: Inside Nissan's Tochigi Assembly Plant
The Making of a Mass-Produced Supercar
By Ed Hellwig, Lead Senior Editor | Published Dec 26, 2007
1 Rating.Given its limited production numbers and stunning performance, you might think the 2009 Nissan GT-R would get its very own assembly line, a place where a small group of technicians work in near silence, slowly piecing together individual cars like craftsmen in a hot-rod shop.
That thought goes out the window the second you walk into the assembly area at Nissan's assembly plant in Tochigi, Japan, about 60 miles outside Tokyo. There, on various racks and conveyor belts, are GT-Rs all right, but they're mixed in among Infiniti G37 coupes and G35 sedans just like any other Nissan. They're all headed down the same production line and assembled by the same technicians.
So it's not what you might expect, but this doesn't tell the whole story of the 2009 Nissan GT-R's assembly process. There are areas where the GT-R does get special attention from dedicated technicians, but you have to take a few steps back in the build process to find them.
Yokohama's Finest
Nissan's Yokohama engine factory is where the GT-R gets the bulk of its special attention. It's here that a special clean room has been created to assemble the GT-R's twin-turbo V6, referred to internally as the VR38DETT.
This is the most powerful production engine Nissan has ever built, so each V6's assembly is overseen by a single technician who guides the process from start to finish. Watching these men at work, it's clear that the often frantic nature of an assembly line does not exist in this clean room. The techs are never in a hurry. They work quickly and efficiently in a room where both the air pressure and air temperature are precisely controlled to avoid contamination of the parts, the kind of environment usually seen only in the assembly of racing engines.
From start to finish, the entire build process takes 200 minutes. This works out to roughly 27 engines a day at the plant's current staffing level. Eventually there will be 20 technicians working on two shifts to meet the full production goal of 12,000 GT-Rs a year. If there's demand for more, additional workers will be added, but the allotted time to build the engine will not change, Nissan tells us.
When each engine is completed, it's test-fired and checked for power and torque on a dynamometer before heading to the Tochigi assembly plant where the whole GT-R comes together.
Feature
Yokohama's Finest
#457
belieave it or not i actually found vids of the mythical stock GTR...
stock GTR with it's up to 120 mph trapps vs stock Z06 with its up to 127 mph trapps =no contest
http://www.youtube.com/watch?v=0O7Xf0IPiiM
#458
now here we have an again up to 120 mph trapping stock GTR against a up to 123 mph trapping stock F430..again =no contest
http://www.youtube.com/watch?v=HIpBZm4FNas
How about this stock lambo laying to rest the stock GTR
http://www.youtube.com/watch?v=g_28t...eature=channel
#459
Im just trying to paint a picture. The GTR is an amazeing track car. But its no bottom of the barrel exotic with 12K made per year and it's not that fast...a 1996 GTS Viper can trapp up to 120 mph..Even a LS3 base model C6 can hit 117 mph..
All those vids with the GTR so fast are MODDED GTR's...But in stock form a gallardo or f430 will rape one. Nothing impressive about up to 120 mph trapps...
#460
Killmall
What I said before as far as the GTR, lambo, GT3 are PERFORMANCE WISE stock for stock are in the same class and have close numbers 1/4mile, track etc...I said nothing comparing of price, production and style.
To Wesman read the info on the vid before you post up again "those aren't stock cars"
STOCK GTR VS STOCK GT3...
http://www.youtube.com/watch?v=jrd8VzfZzN8
