Street Racing & Kill Stories Basic Technical Questions & Advice
At the track and on way home
Old 01-31-2012, 07:58 PM
  #121
bh353's Avatar
Originally Posted by ohioborn80
You so totally missed the whole point.
What point did i miss? For the past year you have pumped up the 5.0 like it was god and nothing LSX could compare...
bh353 is offline
Old 01-31-2012, 08:01 PM
  #122
willizm's Avatar
This is true. Ohio's car runs good for what it is and what it has, but the 5.0 isn't gods gift to automotive engineering either.
willizm is offline
  #123
ohioborn80's Avatar
Go back and read...But since you say that. The 5th gen that made 660whp running 12.6 didn't compare at all. Or the Fodoby's that had cams and 100 shot sure didn't that was there. With there 12 second passes. And the 06 GT) that had 3600 stall C/H nitrious running 12's sure didn't either. Or the Turboed G8 that ran 11.9.
That is same night racing. Not well one time this guy or car did this. Same night with me and them. Funny here most guys say with c/h every fbody should run 10's easy. With the 100 shot should went deep 10's. The GTO should have went 10's from what you said before.
ohioborn80 is offline
Old 01-31-2012, 08:02 PM
  #124
redctsv's Avatar
Originally Posted by willizm
You jus jelly bro. Your 7.slow couldn't brake 10's with 50 psi's
:jk:
nope it needs only 0 psi to run 10s. And if you count the + 1000ft of DA that day It technically ran 10's with NEGATIVE PSI!!!!
redctsv is offline
Old 01-31-2012, 08:03 PM
  #125
92cobranotch's Avatar
how long has he owned the auto? How many passes has he made? By all means **** him out in a few months but give him a little time
92cobranotch is offline
Old 01-31-2012, 08:06 PM
  #126
ohioborn80's Avatar
I geuss some people don't understand tuning stuff like shift points. Tweaking stuff. And the aspects of a stock auto not leaving as hard as a manual car.
Old 01-31-2012, 08:07 PM
  #127
bh353's Avatar
I don't give a crap about a fifth gen..A fifth gen even makes my car feel light when comparing the two...C'mon man 20lb's of boost and it makes alittle over 800rwhp?
bh353 is offline
Old 01-31-2012, 08:08 PM
  #128
ohioborn80's Avatar
Friend of ours got booted in his Z06 this weekend. Very first pass. 10.9 with tire/tune/cold air only. It had more in it I am sure. Just never got a chance. WHich was kinda messed up cause I got warned they would boot me but never did. Buddies SL65 never got a warning running lower 11's. And of course Lethal Owner ran low 10's with no bar or nothing. Guess who all you are and what not.
Old 01-31-2012, 08:09 PM
  #129
bh353's Avatar
Really? a auto is the easiest car to launch..Push the pedal and you go.
bh353 is offline
Old 01-31-2012, 08:11 PM
  #130
Imstock2's Avatar
I agree with ohio... power per liter the coyote beats the ls....But it also weighs a lot more. I hope gm comes out with a dohc v8... dohc ls7 would be nasty
Imstock2 is offline
  #131
redctsv's Avatar
Seeing that the car is an auto and takes absolutely no still what so ever to drive, Sorry cant do that! If he was still with a manual I can see your point!
redctsv is offline
  #132
ohioborn80's Avatar
Its a auto with a stall. Same set up in a manual would make about 900whp. Not to nmention stock cams/heads.
Old 01-31-2012, 08:13 PM
  #133
ohioborn80's Avatar
Yet an auto also can't leave as hard as a manual without a stall. Which can kill it at the track.
An auto also takes more tuning then a manaul car to shift right. Which is the biggest part of the car right now. Even with a stall it wouldn't be at full potential till that is fixed.
Old 01-31-2012, 08:14 PM
  #134
bh353's Avatar
So now we get the "he has more liters than i do" excuse...lol
bh353 is offline
Old 01-31-2012, 08:16 PM
  #135
ohioborn80's Avatar
Nope we get the 115k plus ZR1 with 720whp couldn't run as fast a SC 5.0 at full weight and is still a DD. 20lbs of boost or 100 it ran slower. SO what teh excuse.
Old 01-31-2012, 08:17 PM
  #136
Exclamation
do you really think this? And really think its the fastest its gonna go? There is alot to setting a car up. He has had this car how long. At least he post what it did didnt bullshit or hide a thing.
Old 01-31-2012, 08:23 PM
  #137
toxic99's Avatar
How the **** does a 5.0 with a m6 go from 3400lbs to an auto weighing in at 4000lbs...
toxic99 is offline
  #138
ohioborn80's Avatar
Just so those are not tracking car has been running with the blower for about 3 weeks.
Also nothing to hide. As mentioned earlier I could just mentioned the 10.5 and that was it. But yet I even said I thought was a fluke run.
  #139
the point is he goes from bolt on m6 car to 600 auto car.different animal. Whos to say everything is dialed in exaactly right yet? If you all are correct its never gonna go faster than11.0 . We will see lol
Old 01-31-2012, 08:24 PM
  #140
ohioborn80's Avatar
My 5.0 was a base model with weight reduction. It weighed 3580 with me in it. That weight was also before shedding another 60-75lbs or so. Auto is loaded and is just under 4000lbs with me in it. No weight reduction at all. Even had spare in the back and a 290 piece craftsman tool set.
Quick Reply: At the track and on way home
