Mach at the track
#3181
Obviously the air may have been a little better or worse but results are results. He said it himself that even after along period between tracking the car it was still much faster with longtubes. Best I can do? lol It is real world results that come from a credible non bias source. So your mach mada 308std with boltons yet there are machs wit full boltons making 340+std. Yea let me tell you. Nothing outside of a xpipe will make power on a mach
I hope you are trolling. If not you are giving Morbid a run for his money on being the biggest dumbass in the S/S of MF.
And Morbid straight embarrassed your *** on MF. Thats why you can't stop talking about him, Crawfish.
#3183
#3184
Did it? Must be a typo in the hp rating then. That car shoulda been rated at 335hp with that exhaust. My 99 SS was rated at 327 with that exhaust. They had a bump in power in 01/02.
#3185
#3186
Sure is the stock exhaust. I thought it had the stock exhaust. I never seen a test where the SS had all the performance options on it from SLP. It's a shame too. I would love to have seen where the SLP optioned SS would've stood.
#3187
My Mach made 317 with weld in flows, tune, and an ORX through 4.10s . It was the 3V that made 308. ....340 na with boltons, get a grip on reality. You can't be that stupid. So now Machs make the same power mod for mod as an LS1. Just stop it man, you are worse off than you realize.
Morbid didn't own ****. He banned me when I got under his skin because of the constant truth bombs. He even stated at one point a converter even with lockup will not net any mph gains. Yet you yourself have seen mph gains with one hmmm seems like an intelligent man I tell ya
#3188
Depends on what your trying to do. 3.90's would be optimal for drag racing.....3.73. for street racing.
Same for the cobra 4.30s would be fine on the street but 4.56s would be optimum for the track.
It's no use adam.....he don't understand gearing. He's not bright enough to figure out that the cobra/mach actually has more gear until 3rd gear even with 3.27's. 3rd gear is about a wash with there being about .1 difference.
#3189
#3190
I understand morons. You are just to blind to see the big picture here. Regardless of the gear ratios of the t56 or 3650. When you add that much gear it is going to be a night day difference. Going from a 3.42- 3.90 is not as big as change as going from a 3.27 - 4.56 regardless of the gear ratios of the trans.
#3191
317std? Can we get a dyno sheet of this? Actually the Bolton record is 35x std or 34x sae. Showing how dumb you really are I see
Uhhh, yea he did. Over and over again. I'm talking he straight grudge fuked your *** while the entire MF S/S section laughed at you. Then StkJck permaband your trolling ***!
Just to be clear, you are telling myself and all the other members here that a bolt on Mach will dyno 340-350 Rwhp? Same as a bolt on LS1? Just want to make sure everyone understands what you're saying.
#3192
#3193
"...it comes in the form of an SS spec 325-hp version of the Chevy's rumbling, grumbling, Vette-derived 5.7L LS1 V8; a factory installed ram-air style hood and cat-back center-outlet exhaust system which are supposed to be good for a few more ponies, though they didn't prove so on our test."
So either the editor is totally clueless or the car in pic wasn't the actual test car since it obviously doesn't have it.
#3194
Did you guys even read the article? It clearly states:
It just says "SS spec"
#3195
The only "power" options offered by SLP for the SS was exhaust (CME, Dual/Dual) and air lid (SLP or SLP/Donaldson blackwing). My '02 had the CME and blackwing.
#3197
Std numbers on a dynojet. And yes, I'll post it as soon as I get off work.
Sure let's see those 317std numbers with k&n filter, xpipe, mufflers, tune
Wrong. Btw this post is very homo like. Just saying. Not to mention you are getting fucked up in this current argument. Much worse then what you do to morbids *** in your down time
I am saying that with full boltons they will make 340+std.
#3198
Sorry to keep you waiting sir. Some of have J-O-B's.
307/332...the 317 was the RWTQ on the S197 with some crap bolted to it. My bad, Crawfish. Uploading the graph fwiw. Pretty much further proves my point about your 350 RWHP Bolt-on Mach BS, lol
#3199
Autoderp, I read all that **** over on MF. Your *** got torn to PIECES. You got tossed like a rag doll over there, son. Are you really naive enough to think that EVERYONE is wrong and you're the only one who is right? I think you have one of the worst cases of Narcissistic personality disorder to ever go undocumented.
#3200
Thanks for proving me right. Next.
Read it again, doesn't say anything about an SLP package. Just says "it packs more punch then a Z28." Probably GM attempting to sell the SS as having more HP then the actual Z28 basemodel. Besides that the car they used is in the pictures and stated in the text "You can order your 35th anniversary SS in coupe, T-Top coupe (our test car)". It does not have a SLP dual dual exhaust.
