Mach at the track
#541
If someone is running a stock 302 block, they aren't very serious about horsepower, lol. They will split in a hurry. The mod blocks will hold the power but the internals are crap.
#542
And when people talk about "crazy," they aren't generally talking about something that somebody can do (full weight, at least) with stock LS1 internals, either. I'd love to drive a properly-setup 400rwhp GT to see what it's like.
#546
I've been to a stock 302 block race and I can promise you they are making more than 400 rwhp with stock blocks. Far as I've seen, stock 302 blocks can take around 475-550 with stock internals...with the rotating balance zero balanced and and a good tune, I've seen them last with over 600 rwhp. I'm not saying they will last a long time at over 600rwhp, but they will last a little while.
#547
I've seen them break at h/c levels too. The problem is we don't know what people are doing to keep any of this **** alive. Could be half filled blocks or more, girdled up **** or many hours spent in stress relief.
#549
I cracked mine at 530RWHP(16psi S trim). Totally my fault. Temps dropped and I added a lil timing on top of a Larocca tune with race gas added. BOOM.
You break one with heads cam you are a moron....
#550
"girdled up **** or many hours spent in stree relief" wtf does that even mean?
"How did your block stay together behind that turbo!!!???"
"Dawg....I massaged that bitch with my hands for 2 weeks!"
#552
All a girdle does is hold the two halves together when it splits. Pouring concrete in them would probably help if they had weak cylinder bores like a 400. Breaking all the edges of the mains wouldn't be a bad idea, since it's the thin main webbing that starts the block splitting in two.
#553
Well having to put a hole in the block for the cam I'm sure doesn't help either. All the 302 blocks that I have seen split, the crack goes right through the cam hole.
I've never seen a block split while N/A unless there was catostrophic failure due to a rod or something like that.
#554
However I do like main girdles because they do help with cap walk.
#557
#558
