ls1 Trans Am vs 2014 5.0 Coyote
#402
You do realize that increased bore and/or stroke will add zero physical size to the motor right? ...and I'm the dumbass...
#403
Does the physical size of an engine block get bigger if you add displacement? Maybe I am missing something here...
#406
Lets compare a gt500 to a zr1...lets compare a z28 with the ls7 or a zl1 to a boss any way you put it gm wins...
#407
#409
Yes it does,when the block is already maxed out...just like all ls blocks are the same size and bores are different which makes thinner cylinder walls..the ls7's can't handle boost like a ls 3,because the bores are smaller..
#412
You win, lol..... my bores are 4.125, how much boost can I handle?
#413
No, no it doesn't. Look here cupcake, adding size via bore and stroke changes nothing as far as physical exterior dimensions. Wrap your tiny, little water head around that idea, and then try to absorb this one...the coyote isn't maxed out.
#414
Ok dumbass..How far can you oversize a 5.0?Please tell me the max bore and stroke..because im gonna drag your *** down the street with your lame *** answer..
#415
***Repost Police***
Same thing with this statement. The Coyote is quite a bit smaller than the old DOHC 4.6, which I'm guessing you're thinking of here.
#418
I'll answer for him...You can't bore them at all. My guess a you might get to 5.2L with more stroke.....but no more than 5.4 for sure. It's why I have said their handicap is their displacement. Not that they can't make plenty of power if you know what to do with it.
#419
Before you start crying about price, or bring up another lame argument...remember, the bore spacing is shared with ye "old" 4.6 mod blocks...and what size have we seen them reach from the factory? Exactly
#420
