Nick.H @ the track
The energy stored in a flywheel not only smooths cylinder pulses but also helps to accelerate the car. It does this by storing and releasing energy. A lighter flywheel removes rotating mass from the drive-train but since it does not store the same amount of energy as the heavier stock flywheel, it does not give as much energy back to help accelerate the car. Read up on lever (moment) arm as applied to torque. It is not related to i4, v6 or v8. It is physics which applies to all things
Thanks...100% agree, backs up what i read a wile ago on a ls1tech.. with lunching a 3400 lbs car with traction all the rotation mass on a heavier clutch an flywheel will help.. but to heavy (my opinion) of one will hurt ur ET.. so there should b a sweet spot in the weight.. agin my opinion.
When I replaced my clutch and flywheel, I did quite a bit of reading on this since I wanted to know what the pros and cons were. For drag racing where achieving the lowest ET is important, getting all the stored energy to the wheels as quick as possible will give you lower 60fts which also reduces ET (assuming traction is present). The heavier flywheel will do a better job at this than a lighter one.
Here is one articles that I had saved at the time:
http://www.stangnet.com/mustang-foru...ywheel.576766/
Drove my buddies 996 Porsche, they have a way light clutch, a bit more " finesse " is needed do to the light clutch, put a heavier clutch in there and normal driving from a stop would be a breeze due to the rpm raising higher as you let the clutch out without having to give it gas. A lighter clutch is harder to launch and slip the clutch
This is a V8, not an inline-4. There is plenty of rotational mass and torque due to the large crankshaft and 8 pistons. Only thing I would worry about with a light clutch is the durability.
And I sure as hell wouldn't buy a heavier than stock clutch, certainly not with the minimal mods here.
True with flywheels also. Light weight aluminum flywheels removes rotating mass from the drive-train since it stores less energy. Because the lighter flywheel stores less energy, it works well in situations such as roll racing. On the other hand, since it stores less, it also returns less which does not work well in a situation such as launching your car at the track.
You have to almost decide what you want to do with your car and then buy the appropriates parts to help with that.
Moment from Force*Dist-lever arm I'm assuming you're talking about the moment the clutch assembly puts on the crank as it spins correct? That's fine but remember inertia works both ways. Once you have it going its not hard to keep it going. BUT thats not what an engine does from the time you leave the start line to the redline you are trying to accelerate a mass which has to overcome that moment of inertia. You are, as you said storing energy in the flywheel at this point, energy that could be going to the wheels. Then when you shift the mass keeps the rpms from dropping very quickly (inertia is released) but then you reengage the clutch and the engine must now overcome that inertia again and then fight it again back to the redline as it once again puts energy back in.
Storing energy at 6k is not necessarily a good thing...
Imagine you are turning a 10 foot dia windmill by hand that weighs 200 lbs. Now imagine that windmill being 6ft in dia and weighing 130 lbs. Which will be easier to spin and take less energy from you? The same goes for an engine at 6500 rpm all the extra energy it takes to keep that clutch spinning is hp lost to the wheels. The lighter assembly will make the car a bit trickier to launch but theres an easy fix for that, more rpm or more air in the tires. Mustangs use a 40lb clutch and some go lighter while fbodys weigh over 50lbs, theres simply no need to be that heavy it just hurts everywhere in a 3500lb car.
Mach just curious because you mentioned moment...What is your profession?
And unless Nick gets a stupid deal on an ls6 or buys the new dorman copy he should look out for a used fast. The days of a cheap ls6 manis are over. I got 675 for mine a few months ago with fuel rails/injectors on it. Then bought my 102 with ls3 injectors and rails for 750.
Monster makes great clutches but people jump on their dick so much on here its annoying, fact is the clutches are VERY heavy and I personally dont think they drive that good after being in multiple cars with them. People overlook the weight and just go with it because its the brand everyone has. However they do hold a good chunk of power so its all about needs and wants.
Stock '99 WS6 LS1
Flywheel:__________25.5 lbs.
Pressure plate:_____22.0 lbs.
Clutch:____________5.5 lbs.
Total:_____________53.0 lbs.
LS7 setup:
Aluminum flywheel #198171:_______13.5 lbs.
GM LS7 pressure plate from #24238412:____25.5 lbs.
GM LS7 clutch from #24238412:___________7.5 lbs.
Total:________________________________46.5 lbs
Just found this.. Looks like a good set up to me. Lil bit litter but enough to keep the energy alive and transfered to the tires..
LS7 setup:
This^^^
This is true for launching, a heavier flywheel is better because it stores more energy ie inertia. However after you launch that inertia is doing nothing but slowing you down.
Most of my electives in college were ME and Physics classes which is probably why I mentioned "moment arm".
Oh good stuff brother, well if you have an contracdictions to what I said feel free... lol I'm Mech E, just getting done with school and job hunting lol. Most of my electives are electrical and higher level fluids/thermo based
I wouldnt run the ls7 because of the self adjusting pressure plate alone. That design sucks and is what causes a lot of the shifting problems that plague ls cars to begin with. Blocked out of gear and clutch pedal on the floor being some of them. It can also be hydraulics.
By the time you factor in an alum flywheel also you are in the 600 rang so its not a great budget option
Good luck with the job hunting! I think you picked a good time to be an engineer since the US currently has a shortage of them. You will do well.
You guys arguing the light weight clutch/flywheel thing are funny. You dont have to be an engineer to figure this stuff out, the testing/results are out there for everyone to see. A light weight flywheel in a relatively low powered car (e.g. op's car) will almost always cause bogging issues, which will kill your ET. And no, the small benefit of putting a ****-hair more power to the wheels for the rest of the run will not make up for it. But don't mind me, I know nothing about making low power combos go fast...
Camaro vs Mustang barona drag strip - YouTube
as promised, videos of me going painfully slow. And hating every second of it. And wanting to sell my car.
FYI.......Auto converters can be as much as 30lb lighter than stock.
Not just a 5br0......mustangs since the 70's have had a 40lb~ clutch.
Stock '99 WS6 LS1
LS7 setup:
LS7 setup:
No they're not... stock hydraulics are ****.
Don't waste your time with a new MAF, just go SD.
What kind of gains did you seen goin SD? I still have a maf.
It's not there for everyone to see. I seem to have pretty good results with a light clutch/fly. Most guys do not run 100% traction, a heavy clutch/fly is only useful when that energy can be released instantly. Once the rpm has dropped on the heavy clutch/fly it has to be reaccelerated. I'm sure you know what weight does to acceleration.
But i would like to hear if and what you have run for clutch/fly combo's and your results.
I was not saying the Porsche had poor drivability due to the lighter clutch, just a bit more finesse for everyday driving. If you were to teach a first timer how to drive a manual, same car, they more than likely would struggle more with the way light clutch as opposed to a little heavier one
