calling out fox bodies
More info man. Actually no.....you should really edumacate you self. Ls stuff can get to 600whp~ na with gm stuff. That would be a ls7 with a gmpp stage 3 cam. Plus you have 2 different ls crate engines to pick from. One with 620 and the other 700+. You should step outta furd land.
When buying GM crate **** is more expensive than using the aftermarket to modify or boost an engine, what's the point?
Let's talk about LS7 engineered ****, dropping valves like they're hot.
Bad example of any engineering merit
The LS motors have plenty going for them, but they're not even close to as good as you think they are. Nothing about their architecture is groundbreaking.
You can look around on here and fine ls7 stuff all the time. That's the great oart about chevy stuff. It's not like the furd **** where decent stuff is like finding a needle in a hay stay and costs a arm in a leg.
I think if the valve issue was that bad there would have been a recall. But uf you really wanna talk about **** blowing up look into termi stuff. Lets take a look at you awesomely engineered 30poo block.....
keep yakkin snake . You're looking dumber all the time
I'm making well over 400whp with a engine from 2002......you're comparing built stroked furd **** to it. Yes the ls is as good as i think. And it's alot better than you give it credit for.
Since you asked in your own vacuous and inane manner, the LS7 valve guide problem is attributable to Linamar Corporation, the third-party supplier contracted to machine LS7 heads. This is not exactly an unpredictable result from the manufacturer whose single biggest customer is Ferd Merter Co.
I guarantee Toyota's recalls were from a defect that could be narrowed down to a supplier as well.
Hio, I give them credit, just like I said - the architecture isn't groundbreaking. The fact you want to compare an all aluminum 5.7 debuting in the late 90s to a 60s tech 302 is a compliment to Ford
See what I mean? You can't even have a conversation without mixing in opinion and calling it fact Upgrade Your Small Block Ford's Heads - YouTube
before you speak you should look into it codyvette.
504hp junkyard 302. 504 hp with kaase p-38 canted heads.
they are not Windsor parallel valve heads. these are canted no compromise heads, and full porting opens more power. Cleveland power in a Windsor block.
Didn't Mike and I already discuss and conclude that my old 87 coupe was as fast as his L98? Faster with gears and shifter, but stock we said it was a toss up? Explain "killed" with something other than your personal preference.
Vettes compete with Mustangs now? You know I meant f bodies, goofball.
SNAP!
Lol! I was comparing 2 cars with very close times and we both know the guy more than some stranger. We both knew the car, well actually turns out I didn't but you know what I mean. It's someone we know and we both recall his personal experience, and could contrast that with my personal experience.
