calling out fox bodies
Im not sure I see a cam only LS motor making 470whp. I've seen max effort H/C set-ups make 500whp. Which, is pretty bad ***, but that's probably a pretty radical cam, compression, etc. The fox I posted was on pump 93 with a 10.4:1 CR and what looked like a simple cam set-up.
i would actually expect a cam to give me about 60hp~
Hio knows nothing of SBFs. It's okay, we're all clueless about something.
It's cute how you call my responses novels when you have no retort
Man you get roughed up when it comes down to an intelligent conversation. What's the matter, 6th grade comment strike a nerve?
As I said, 347s and LS1s should make the same power when going heads/cam, Mustang wins because of superior chassis. Bolt ons isn't close because foxes use a head that was designed in the early 80s.
As you said....blah blah blah blah.
Mustang and superior chassis. .....you read that somewhere cause your results ain't proved that. It's lighter.....by alot. If you think that means superior you're wrong.
If the furd engines were so great no one would be swapping in chevy stuff would they?
before you speak you should look into it codyvette.
504hp junkyard 302. 504 hp with kaase p-38 canted heads.
they are not Windsor parallel valve heads. these are canted no compromise heads, and full porting opens more power. Cleveland power in a Windsor block.
My bad man, it was a mistake on my part. I should have specified. Thanks for the examples. That's pretty good on a stock headed car.
So just how much property do i occupy in that puny little brain of yours. It seems to consume you.
I've mentioned something like that before....lol
Actually no.....you should really edumacate you self. Ls stuff can get to 600whp~ na with gm stuff. That would be a ls7 with a gmpp stage 3 cam. Plus you have 2 different ls crate engines to pick from. One with 620 and the other 700+.
You should step outta furd land.
What I've always like about gm stuff is i can get it done with production parts good enough for me. That helps keep costs down and support other bad habits
