Epic SRK B/S thread of 2019
#2521
Snail0.5 queer bait is on here bashin people's **** and his queer car can't make a small road trip.......true starry of a ***.
Qtr mile is less costly for the day mostly easier on parts. Again you have no ******* clue.
#2523
I'm not bashing ****, I'm giving you a little dose of your own closed minded bullshit and your head is about to implode because of it.
Why build your car for road racing when all the racing you do, when you do, is 1/4 mile?
13 hrs one way isn't a little road trip especially in the southeast where it's a billion degrees right now. Why put 800+ miles on the car when it can be trailered? That's common sense.
You're a hypocrite and as usual you've been schooled. You don't road race your race car, you use that as a built in excuse for the results. You always have 6 built in excuses for every car you touch
#2524
No you're not.....you're simply looking like a idiot as usual.
My excuses for my cars are they are both bolt on and both would drag you hard enough you would have to check if your key is still on. Think 12.2@114 but putting 2-3x that distance on you.
#2525
Cars need to be set up with oil coolers on everything to for road racing. I don't want that much complexity or weight in my 4gen.
I woulda also had 5th/6th faceplated then. That is typical of a road race t56.
#2526
Both your cars are engine swapped built bottom end projects. If you're gonna go through that much effort they should both be mid 10s cars easy for how light they are. You'd absolutely rag on a mustang for decades if they were engine swapped, running a CF driveshaft, FP Trans, Ford 9" rear, race seats and no airbags at between 2900-3100lbs and still never hitting a 10.5. That's a FACT.
Inb4 deflection #9001 because you don't have any relevant **** to say
#2527
You still cryin after getting i see.
I told you a legit answer. I can't help you're to ******* stupid to understand it. So like a dem you keep dancing as i you into the next century. Just like a dem you keep lying......like a trump i body slam you like your cnn.
Neither of my cars has a 2900-3100 rw. Both are much faster than you with oe heads/cam-s. You suck so ******* bad not even the aftermarket can keep you from getting mopped.
Fact is i went 10.7 in the camaro with a bolt on ls6. No built bottom like you claim........and never got to run the old 90k mile ls6 in it's finest form. You think you shed alot of tears now. My god the tears you bitches woulda shed if it woulda make it to the rental.
You shoulda went to the rental. Sxc woulda had a great time gapping you with a old mbo ls1.
I don't have to road race to enjoy a good handling car. Maybe that thought process is beyond what your pea brain can handle......seems perfectly logical to me. But a dumbass bitch like you will still cry like you did when Hillary lost.
So what we end up with here is both my cars are way way faster than yours. It's sad that you get walked like a dog with a max effort h/c fox by a 12.2 car. I can see why the salt stays in your vag.
#2530
Point is you're the kind of clown who does aftermarket suspension mods but has to give it a gay label in order to make yourself feel better. Everyone else in the car world would just say their suspension parts, but since you're apparently insecure about your car's performance you need to try to call it something to sound less effective. All drag race times, no road race times. Sad face.
In closing, you tried to change the subject 9 times, changed the focus to politics, brought up irrelevant events and even other members to try to get the focus away from your cars performing like **** then you resorted to lying as the cherry on top. Too bad I don't get distracted easily
For the member who criticizes every other car, you've invested more time on your engine swap cars than basically any other member in this section has on their car, and the best we've seen is a 10.97 and an 11.2 from your boosted lightweight coupe. Depression.
#2532
7 Second Club
Damn you sure are Triggered like a transgender that can't use both bathrooms
#2533
Hio: “You fk’n dumbass, Nate! You are not allowed to talk in this section at all since you don’t go to the drag strip every single weekend and Tuesday nights.”
Also hio: “I don’t have to road race to call my car a road race car. You see, it’s that little pea brain of yall’s that can’t comprehend simple logic like this.”
Hypocrites gonna hypocrite.
#2534
#2537
Muh notch needs a better tar to gap you even farther.
Seems as tho you're doin all the car criticizing. I'm only spitting troofs on your turd. I mean it's a actual ******* turd. Hits 3rd gear and just ******* dies like the rest of those 30p00s.
So now all suspension parts are the same. You're quite the car idiot. Just say suspension cause they all the same eehh snail0.5
I know which bathroom i belong in but it looks like you think it's ok to choose.
Dumbasses gonna dumbass
Lmao
#2538
