Wilwood SL 6 piston VS Brembo CTS-V 4piston
I'm about to upgrade my LS1 SS brakes sytem and have a little problem. Stock brakes right now, but I have a wilwood SL 6 piston set-up. I also have the brembo cts-v set up. My question is which set-up should I go with? Which one do you guys think might be better? As for rims I have 18s C5Z06. thanks for any help
http://www.frrax.com/rrforum/
I don't know if you are familiar with this website, you may find threads on this site that have come up with this question.
frrax = f-body road racing autox, so there is a LOT of knowledge there.
Chances are, you're going to get great reviews on Wilwoods by folks who have Wilwoods, and great reviews from f-body owners who have the CTS-V setup(but I don't think there are many, if ANY, f-body owners who converted to toe CTS-V brakes.).
I could be wrong though.
you'll hear folks who say that the C5 brake conversion is great, Wilwood's are great, Baer's are great, AP Racing's are great, Brembo's are great...
take note with the folks who have had the above and who changed theirs to the Wilwood's or the CTS-V brakes.
Good luck!
Good luck!
Well, see, I don't know what you have exactly, but I can tell you what I have, which is the Wilwood 6-piston fronts with 2-pc 13" rotors, unsprung weight savings is about 17 lbs lighter than stock. Stopping power is OUTSTANDING compared to factory. rotors are far superior to factory rotors, not to mention that they're a lot lighter.
I don't know if your CTS-V setup has 2-pc rotors, I'm ASSuming you would have to make brackets for the CTS-V calipers to fit. do u also have the CTS-V rotors as well???
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
With the CTS-V Calipers (04-08). We use the C6 Z06 front brake rotors 14", b/c the caddys are 6 lugs and f-bodys are 5 lug the caddy rotors will not work. so the new vettes are also 5 lug.
also the "bracket" is apart of the caliper its a 1 piece fixed caliper.
the CTS-V calipers are direct bolt on (2 or 4 washers are need to space the caliper around the rotor) then theres the issure of the caddy calipers clearing the spokes of the wheels, since the caddy calipers are very "WIDE". i have 4 - C5 Z06 18x10.5 and still need 1/4 clearance so i am gonna have to use a spacer with the wheels to get the spokes out away from the caliper. Then caddy brake lines are needed b/c f-body brake lines are not long enough to reach when turing the wheels.
Just do the Wilwood SL6's and bolt it right on the car, bed the brakes, and your ready to rock ! I have the SL6's up-front and the 4 pistons in the rear and this car stops incredibly well. My vote, obviously Wilwood
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
