Bilstein shocks for 2004 pontiac GTO
LS1TECH Sponsor
Koni has shocks for it, but I don't believe Bilstein does.
__________________
LS1TECH Sponsor
I have other parts too. Brake parts, other suspension parts like springs, and swaybars. Exhaust stuff.. The usual.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
LS1TECH Sponsor
I don't do set up by e-mail (let alone on open forums). I don't make springs for the GTO, and not sure you need springs (not everyone does). In fact I'd be more prone to Koni's and bars before springs since it's a daily driver around Chicago.
Happy to discuss the matter with you by phone.
__________________
Sounds good. I will give you a call when I'm ready to get some Konis. We'll talk about other stuff then. Right now I'm doing a ton of research on my own. I'm trading in my Z for a goat in the summer. I've read about GTOs stock springs being really weak and causing tire/strut rub. You're right, pot holes around here can eat the entire car. Definitely don't want to overdo on the springs. I had some 1LE springs/shocks/sway in my previous camaro and loved the improvement over stock. Learning about GTO's suspension now and I feel like a noob right now.
LS1TECH Sponsor
Springs don't cause the tire to rub the strut, that geometry is fixed.. the spring is mounted on the strut. I'm sure someone put big tires on a car and might rub more often with stock springs, but then that's not exactly the way the car was designed either.
__________________
