ATE PremiumOne Rotors--Free shipping on full sets through 4/30
The subject line says it all. Through the end of the month we are shipping any order of 4 ATE rotors for free (within the continential US only, call for shipping elsewhere).
A set of 4 LS1 rotors is roughly 80lbs, and shipping on those can run between $40 and $60 normally, but until the 30th you don't pay any shipping. This sale also means that a set of normally more expensive ATE's are actually going to get *to your door for LESS* than a set of uncoated Brembo's.
http://www.stranoparts.com/partdetai...ID=0&ModelID=7
ATE is a German company, and a division of Continential/Teves. If you want to read more about ATE, Continential/Teves, or the Rotors themselves head here: http://www.ate-na.com/generator/www/...rotors_us.html
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Your best bargain will be to order a set of the ATE rotors, and then a set of the LS1HPS set of pads (also have free shipping on the pair).
__________________
Sorry... But I might be able to knock a few bucks off the shipping for your Jim since you already bought the fronts.
__________________
Slotted only, ATE does not do them in blanks at all.
LS1 front/LT1 rear set would be $315 and also subject to free shipping through the 30th.
__________________
Added a set of LT1 Rotors... $276 shipped (through 4/30)
Link: http://www.stranoparts.com/partdetai...ID=0&ModelID=2
__________________
No listing for C6 Z06 rotors.... Sorry. C5 Rotors, yes, C6 Z06, no. I do have DBA rotors for that car (they are not on the site) they start @ $147 each. They can go a lot higher as you get into the 2-piece designs.
I also offer Racing Brake's two piece rotors for the C6 Z06.
__________________
Yep, 2-piece. Racing type with an aluminum hat and replaceable friction ring (rotor). Lighter and less warp prone.
The Racing Brake 2-piece for Z06 brakes are $400 each.... but then they also weigh 17 pounds each vs. 26 for a stock one-piece rotor. My website is not setup in a way I can put all the information up, so I'll forward you to the Racing Brake site specific to the Z06 rotor: http://www.racingbrake.com/Z06_FRONT...p/2072-311.htm
Note I sell the rotors for less than they do, so if you would like a set, just let me know and I can take care of that for you.
__________________
Ceramic rotors are HUGE money (and not aftermarket parts). You don't want to go there. They are also kind of touchy and grabby.
__________________
