Well I'm Pissed.......
Went to a swap meet the last weekend in april and I found an LS1 brake kit for my car. I bought both spindles, rotors, wheel bearings, and drivers side caliper and bracket for $40. I was pretty stocked for the good deal, brought them home and sandblasted the spindles and got them all painted. Well today I finally got some time to install them and guess what.......******* drivers side knuckle is bent and the wheel bearing is bent too. The top of my wheel hangs out past the fender about 3" so its bent really bad, I can't believe I didn't notice it before hand but I didn't.
So now I guess I have to put the LT1 brakes back on since I really can't afford to buy the knuckles right now.
So I guess I'll get some good pads and test fit the passengers side to see if its fucked up too.
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
That sucks man.
Who the hell sells bent spindles?? The guy selling them had to know they were bent, the car must have been in a wreck or something.
I'd question the other side too. If its even a little bit bent it will throw off your wheel alignment pretty bad.
But I couldn't ever sell something that was junk, I couldn't sleep at night if I did
Yeah I hear you, but I should have been skeptical since they were only $40 to start with. I'll test fit the passengers side and see how it is, but now I think I may be better off just getting a different complete setup.
If ones bent, the other probably is bent to some degree too. It takes some force to bend a spindle.
Too bad about that, the LS1 brakes are a very nice upgrade.
Thanks to InsaneAuto86 hopefully I'll have the brake swap done next weekend and have the car back on the road after a long winter
All that is needed is.....
rotors
brake pads
hoses
and I get everything at cost, so I shouldn't do too bad
rotors
brake pads
hoses
