Old 05-13-2016, 02:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevoret Camaro or Pontiac Firebird Brake Guides
Browse all: Brake Guides
Print Wikipost
CTS-V Brake Install w/ Pics
Old 04-29-2015, 05:28 AM
  #601
badformulaLS1's Avatar
Originally Posted by mac62989
Both 4 piston but I don't think the same at all because they fit under 17s and ATS use 12.6" rotors up front.
They are the same caliper, or at the very least they are very very similar. I didn't take a picture but I have compared both side by side. The reason for fitting in 17" wheels has nothing to do with the caliper it is solely due to the fact that the rotor is over an inch smaller than the 14" rotors on the V and 5th gen Camaro.
Old 04-29-2015, 08:10 AM
  #602
maxpower_454's Avatar
The caliper sticks out further radially from the hub than the wheel so it is typically the caliper that hits the inside of the wheel, not the rotor. I'm not talking about the clearance between the caliper and the wheel spokes. That will vary by wheel offset and design.
But I see what you're saying. The ATS calipers were designed for a smaller rotor so the flange on them is different than the flange on the CTV calipers. that flange difference would mount the caliper closer to centerline of the hub and increase clearance. I'm definitely going to look into these because I don't want to go to 18" wheels.
Any other info or pics you have from this swap would be greatly appreciated!
Old 04-29-2015, 09:01 AM
  #603
mac62989's Avatar
I talked to the guy who posted the ATS brakes. He said he will be installing soon. He is using C5 rotors, 15mm spacer, 18" wheels, and he mentioned the stock ATS brake lines. I asked him to post up when he installs everything.
Old 05-07-2015, 11:46 AM
  #604
Joeyofblades's Avatar
How much do we know about the 6 piston Brembos off of the CTSV2? Do they require the same/similar offset to clear? Do they also use c6 z06 rotors 14"? Do they bolt to factory mounting holes on the 98-02 spindles?
Old 05-08-2015, 09:15 AM
  #605
There are some good posts about them. They bolt up but the mounting holes need opened a little. I don't think there is any way they would clear 17" rims. Yea, 14" rotors work.
Old 05-09-2015, 12:06 AM
  #606
Do they use the same brake lines? That sucks the mounting holes need to be modified, I'd be too afraid to mess with that myself.
Old 05-09-2015, 04:29 AM
  #607
formula218's Avatar
opening them up is pretty simple, on the spindle the holes just need to be opened a couple mm. it could be done with a drill or done pretty cheap my any machine shop.
Old 05-09-2015, 04:32 AM
  #608
formula218's Avatar
check out this thread https://ls1tech.com/forums/suspensio...-calipers.html
post 11 he's drilling the spindles.
Old 05-16-2015, 09:14 PM
  #609
chester0001's Avatar
Smile ATS Brembo update
Ok so I insalled the cadillac ATS Brembos and it looks pretty good only issue i have is that the pads hit par of the corvette rotor hats so i had to grind down the pads on that side. I'm looking for rotors that have about 1/2 inch more disc on the hat side you can see where the paint came off. but for now it works and have much more stopping power, and that even before they are bedded in.
Stock Camaro flex lines fit on the calipers a charm, will most likely order braided lines eventually. needed 2.8 mm of shims to center the calipers.
A bit of paint and elbow grease
Old 05-16-2015, 09:51 PM
  #610
mac62989's Avatar
Looks awesome! So your saying a 13.1" rotor is needed? I think C5 are 12.6
Old 05-18-2015, 09:31 PM
  #611
Looks great! Are they 18's or 17's? If 18's, do you have a set of 17s you can try and report back?
Old 05-19-2015, 10:46 AM
  #612
mac62989's Avatar
^Their 18s
Old 05-23-2015, 01:49 PM
  #613
Here is a picture of my 18x9.5 c6 z06 spyder wheels ordered from oewheels for the purpose of fitting these calipers. They have a 40mm offset and a gigantic amount of room for the stock calipers.
Old 06-15-2015, 12:13 AM
  #614
stage274's Avatar
Here is my set up.. 2010 Camaro discs.. 18s magnesium vette rims, needed 20 mm eibach bolt in spacers. Because the offset of these rims are 60 mm...
However, I think the set up looks sick, each rim weights only 19 lbs... And they fit perfect now.. I just called Kor, for the break line kit... It was a easy install.
Attached Thumbnails CTS-V Brake Install w/ Pics-009.jpg   CTS-V Brake Install w/ Pics-005.jpg   CTS-V Brake Install w/ Pics-003.jpg   CTS-V Brake Install w/ Pics-004.jpg
Old 06-15-2015, 01:13 PM
  #615
formula218's Avatar
looks great, i like those wheels.
Old 06-15-2015, 11:36 PM
  #616
stage274's Avatar
I love these rims... I am surprised not many use them.. I think they look really look good on the fbody..
Old 06-16-2015, 10:04 PM
  #617
Atl_monte's Avatar
This seems pretty straight forward if wheel clearance isn't an issue
@Stage are you running the 04-07 CTS-V calipers with the 2010 camaro rotors?
Old 06-16-2015, 11:47 PM
  #618
stage274's Avatar
Here you go.. Yeah 04-07. I paid 350$ or so, for both, with brake pads and pins, all new. Don't waste your time, buying used.. I also bought stop tech rotors, 130 a piece, I think they had a sale on the Cryo ones when I bought...
About 600 bucks. It was the rims and tires, what was the hassle. These are rare rims.. But can be found. I used 20mm bolt in eibach s-10 spacers all around, perfect fit.
These rims have an off set of 60 mm, because it was meant for the euro market. But after the bolt in spacer, they made the wheels and tires fit perfect. The wheels and tires fit, exactly the same as on my 97 Lt4 Camaro. Exact; same distance from the lip of the fender wells, to the the tire.
Also, the bolt in spacer, holds the Camaro disc in place.. Big plus. When I get a rear end, I will just order a longer one, from stock.
These rims are never coming off the car.
http://www.ebay.com/itm/Cadillac-CTS-V-Brembo-Silver-4-Piston-Rear-Calipers-Pair-w-Brake-Pads-89047742/171275391758?_trksid=p2047675.c100010.m2109&_trkparms=aid%3D333008%26algo%3DRIC.MBE%26ao%3D1%26asc%3D31236%26meid%3Dc6b067760d314e6c8b98d4202abc2883%26pid%3D100010%26rk%3D6%26rkt%3D11%26sd%3D251933351439
Old 06-19-2015, 01:41 PM
  #619
Guys I have a question. There's a pair on eBay with a pin kit and a pair of powerstop evolution pads. I want to get this kit but my question is will these pads (meant for the 04-07 ctsv) fit the z06 rotors I will be getting as per this guide? I know you should buy pads and rotors together but this is a good package deal and I'd like to use these pads. I can message the guy and ask him to take off the pads but he's including them for an extra $40 so its a good deal.
Old 06-19-2015, 02:21 PM
  #620
stage274's Avatar
Um... Dont use the z06 discs... Use the 2010 camaro discs instead... Also, yes the pads will fit, because I used the same ones... The vette disc, need to be shimmed, and the contact area is not 100% correct.
Quick Reply: CTS-V Brake Install w/ Pics
