A few new products from UMI Performance
Hello Everyone,
We have released a few new small products for the F-Body... so please take a look and let me know if you have any questions.
93-02 Drive Shaft loops- We offer two versions depending on your exhaust set-up. Priced at $94.99
www.umiperformance.com/2025
www.umiperformance.com/2032
Adjustable panhard bar for the budget racer- Priced at $99.99
www.umiperformance.com/2019
A-Arms that now feature polyurethane bushings on one while still being adjustable- Priced at $378.99 and the kit $547.99
www.umiperformance.com/2305
www.umiperformance.com/230511
UMI just keeps getting better and better. Nice job, Ryan.
FWIW ... 3 years of HARD road racing on a set of UMI LCAs and PHB ... no sign of them giving up. Maybe you build them too good ...
We have a rebuildable swivel joint in production now that will use Delrin as a race. It is a very nice set-up and I am pretty exited to get it on the market! We have been working on it (testing it) for two years now... just need to finish the production.
Thanks!
I apologize, I should have clarified....I meant front lower A-Arms. Sorry.
Here is what we have- www.umiperformance.com/2305
This features poly bushings on one end. If you read the second paragraph in the ad it explains why we still use a rod end on this application and why both ends can not be polyurethane. Our new swivel bushing will be available in our A-Arms as well.
Thanks!
Are the poly rod ends available seperately for front LCA's that currently have heim joints installed? Do you have a part number for them?
I noticed you sell these bushings seperately for panard bars, and rear LCA's, just figured I'd ask.
Hey:
Great!
Maybe next you can make 93-97 auto/4l60, 93-97 manual/t56, 98-02 auto/4l60e, and 98-02 man/t56 tranny crossmembers, without the Torque Arm mount for those of us with tunnel mount TAs. With the DS mount, front area angled off 45 degrees so they don't touch DS cats if used in that area. I'm sure this would be an easy product to manufacture and sell if advertised, since you already have it, just leave off the TA mt, ! less welding process, angle cut the front left, I Don't know why it is there anyway I think it would even look better without it hanging down and 1 less place to make contact without really sacrificing any strength. I know I would buy one like this, if the price was inline with the conversion crossmembers
Dub
When In Doubt Do Without
Great!
Dub
Hey Ryan,
I just got my A-Arms a couple weeks ago, but they're the older style without the poly bushing... I didn't know you guys were coming out with these, can we do anything to swap them out? Maybe just the rod end?
Thanks
Thanks
I was just reading info on both drive shaft loops, and both say that it will not clear 98-02 models with factory y-pipe. So which one should I get? I got an 02 Trans am with stock exhaust but plan on getting american racing longtubes later.
i second on this one. i still got mine sitting here in a box. i wanted adjustable poly. lol
The reason why we say it will not clear is because where they merge the factory Y Pipe but aftermarket Y Pipes do clear with no problem!
Thanks
Brad
Hello
Unfortunately there will be a clearance issues and we are still in development on that particular DS loop!
Thanks
Brad
Great to hear that you are satisfied with the products!
Thanks
Brad
Thanks Mitch and maybe you are right
We do make adjustable control arms with poly bushings seen here- www.umiperformance.com/2018
Thanks!
Thanks!
when are you guys going to make the drivers side relocation bracket for the panhard bar when using the panhard bar relocation kit? jegs is the only one that makes one. ill be needing one in a few weeks.
