Done with my Homemade double adjustable LCA's
All you gotta do now is send them to Silver Ghost, the Powder Pro, and have him coat them.
He did my brake calipers and I can't believe just how well they've held up over the year. As you can image, I put alot of heat into my brakes and I take my wheels and calipers on and off quite a bit and there's not one scratch on them. I couldn't be happier.
Now that I look at these again I'm a little concerned about the L/D (Length to Diameter Ratio). If you haven't already done so, you may want to calculate the critical load to insure that they won't buckle or flex too much under hard launches.
They look good. It is always great to see people showing interest in machining... it seems to be a trait many people don't know and have anymore or show desire.
If you have a local powder coat place they can do them cheap, would look sharp and last long. If not good ole paint will do the trick.
