BMR TQ arm: we hardly knew you
Sry for the large pictures, they are uploaded direct from my phone.
Broken mount <3 Couldnt tell during driving but was under the car and saw. Street driving was too much- Full length, trans mounted, adjustable.
![](http://img.photobucket.com/albums/v626/BuffJoeyD/5f335704.jpg)
![](http://img.photobucket.com/albums/v626/BuffJoeyD/87292f78.jpg)
Sorry to see you have an issue with any of our products.
In the second image you can see where the holes are elongated this is directly due to the bolts at one time being loose.
When the bolts come loose it causes leverage on the bracket and the bracket will eventually fail.
This scenario is well documented here on LS1 Tech.
Now I have the whole Xtreme tq arm set-up. With the Xtreme drag bar and adjustable lower control arms. All BMR suspension up front ie. K-member and upper and lower control arms on my 99SS. I am very pleased with the BMR parts I have.
Yea, those bolts were definatly loose, you can see where the washer head of it has shaved some of the metal away as it was moving around. I've had BMR parts on my car for 8 years and have had 0 troubles. And that's with serious hard launching in a heavy *** car. But, when you start putting aftermarket stuff on your car, you need to check the bolts from time to time, they can/will back out.
Chris
Chris
The damage traces back to a time when the Clam shell bolt broke and trans mount another time- placing the stress on the item pictured. BRM stuff has beengreat, not trying to call out BMR on anything, just sharing how it held up to a beating.
BMR PMed me right away and called me to talk about what happened to the piece and to make sure everything was square- They've been great. Ive worked with UMI , BRM , Sphoon and we make our own suspension parts as well. Everything fails eventually. Just depends on how well it was installed and the environment its driven in.,
Location: boaring place where theres more cows than people
ive had a bmr torque arm on my car for almost 3 years now and havent had a problem sorry to see what happened hope it didnt cause any major damage
