View Poll Results: Which One?
BMR K Member
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
31
25.62%
UMI K Member
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
90
74.38%
Voters: 121. You may not vote on this poll
BMR K Member VS UMI K Member
Dual Tube Center Section Adds Increased Strength over any Competitors Design
http://www.umiperformance.com/catalo...roducts_id=175
From what I have read chromoly is very lite but very weak ... As the guy said about his broke K-member and that was normal lol
Now I do know they make the A-arms in chromoly which I will do.
I think UMi has a set with both K-member and the Arms
Weight Savings with Chrome Moly A-Arms- 35.5 lbs
http://www.umiperformance.com/catalo...roducts_id=146
![](http://www.umiperformance.com/catalog/images/large/fbs002a_LRG.jpg)
I don't think they make one in chromoly... But to be honest I don't think I would want a chromoly K-member.
Chromoly is lighter and stronger than mild steel. The thing is the welding process is a little different. Chromoly is harder to pentrate and takes more attention to detail when it comes to welding.
I've had **** from UMI, BMR, and Spohn.
Call me a UMI nut swinger or whatever but I just bought another 500 bucks worth of UMI gear and I have no doubt that the quality will be outstanding.
EVERYTHING about UMI all the way down to stickers they include with their items is better. Stuff has broken in the past a long time ago, and UMI has made corrections and replaced them. I guarantee that if you had the two K-members side by side, your decision would be easy.
EVERYTHING about UMI is better. Stuff can break and it does but they'll handle it, but if you had the two K-members side by side, you're decision would be easy.
But like you said if the welds suck who care about the part.
As for the (UMI) K-member I have not seen a better looking K-member out there .
This is what i was talking about..... I have read from a few people that the welds on the Chromoly parts would break. And this was a sponsor on this site and they didn't replace his after he showed them.
Chromoly parts when welded properly should be damn near indestructible.
And if anyone breaks a chromoly suspension piece it will clearly be a weld failure. That sponsor should replace that part with no questions asked after forking out that kind of cash. This I know UMI does.
But they do make a road racer k-member but they say "These areas are exposed to more stress from a road race car than a street or drag race car would ever apply"
quote from the Road Race k-member
"When it comes to serious racing you want an item built to withstand high amounts of abuse to prevent failure that could lead to down time and extra cost. Our road race version K-member is designed for the serious racer that exposes there vehicle to more stress than any street car will ever experience. How do we do it? We take are already over-built street K-member and improve it even more. Using additional 1.000” tubing we tie together crucial areas. These areas are exposed to more stress from a road race car than a street or drag race car would ever apply. This item weighs in at 3lbs more than our standard version but still maintains a much needed weight savings. "
http://www.umiperformance.com/catalo...roducts_id=176
Thanks everyone for the positive comments, we appreciate it!
Our K-member is a very well built and well designed item. It is designed to take the abuse of a street car, drag car and autocross. We do not make the item in chrome moly, due to the complex design of this item producing it in 4130 chrome moly would increase the price significantly for little weight savings. Other companies offering this item in chrome moly recommend it to be used for drag race only. This is because there design is much simpler so there production time would be less than half of this item allowing them to sell it less expensive. Like mentioned above chrome moly material is stronger than mild steel since it has a higher tensile and yield strength. The key to chrome moly is the welding process, if welded incorrectly it can crack or become brittle. With an item of this size offering it in chrome moly would take some extra testing and extra cost due to the amount of welding that is involved and increased material cost.
Another note on our k-member. Every K-member that leaves our facility is fully inspected and stamped with an inspection number to reference an inspection sheet. This way we can guarantee fitment every time! Every k-member is also placed on a LS1 block to verify motor mount fitment and prevent you the user from having issues.
If anyone has any questions please let me know and I am glad to help.
Thank you!
Ryan
Thank you!
Ryan
