Want my car a bit lower, already have stranos
Is it possible? I'm throwing around the idea for a winter project. I have Koni 4/3s and Strano springs, but I want my car to sit a bit lower. Would it be possible to do without chopping or replacing springs? I know ground control makes a conversion kit for Konis, but I don't see how it is possible to make the rear any lower without using a smaller spring, heater hose mod being the exception.
Thanks in advance
Thanks in advance
LS1TECH Sponsor
The car has limited travel. And in this case he's looking to lower the rear, from what I can gather. First thing to know is that the axle is bigger than stock, raising the rear vs. a 10-bolt. You could do the isolator mod with my springs for a big more drop.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Actually, does anyone know how far I am from bottoming out my konis?
LS1TECH Sponsor
If you go any lower and don't up the spring rate, by a LOT, you run a huge risk of breaking/bottoming the shocks. There is precious little working travel there to start with, and on a set of my springs as mild as the drop is the Koni has about 55mm of travel left.--that's about 3.6" of actual wheel travel. That's one reason the rates of my springs are what they are.
__________________
Wasn't there a thread a while back about using the lower perch on the Koni's w/ Strano springs along with the Upper Mount Mod to increase the travel? This along with the heater hose mod in back would give an additional .75"/.5" drop over what you have now....that is if it's safe.
Ah ha, this is one of the things I read i think....
https://ls1tech.com/forums/suspensio...i-setup-2.html
Upper Mount Mod
Upper Mount Mod
