will it rub?? Pic added
I was in the same position, as were many others on this board. What I did was shave down the mounts on the chassis to just about where the nuts are for the bump stop. I removed the aluminum spacer, and had a machine shop shave the profile of the bump stop down to where the wheel would clear it while the car was jacked up.
Best pic I have
You could also try buying an after market bump stop that is smaller, after shaving down the mount. None of this is absolutely necessary, it only assures you that when a shop puts the car on a lift, and the suspension unloads, they won't gouge up the inside of your rims.
You're actually catching less than i was. I used an angle grinder to grind the mount back to just about the point where I started get close to the threaded portion of the two nuts. I left enough material to allow the bolts to still hold the bump stop on.
As I said previously, I had a machine shop reduce the profile of the bump stop, to a little more than half it's original width (flush with the ground back mount).
