Best tq arm/least noise for 02 M6?
The longer torque arms will control braking better while shorter arms could actually induce brake hope. The longer torque arm is also very quiet and would not offer any additional noise. Here is a link to this torque arm- www.umiperformance.com/2205
If you want to remove the torque arm from the transmission then we would recommend one of our torque arm relocation kits seen in this link- Torque arm Relocation Kit
Take a look and let me know if you have any questions. Thank you!
Ryan
any chassis mounted torque arm will cause more noise. Its basically like taking a stethoscope to your rear..instead of having a rubber bushing to connect it to your tailshaft then that having a rubber tranny mount you have either a bolted or welded in crossmember w/ poly bushings. I'm running a UMI torque arm but I was having issues with the dsl so I ditched it and got a bmr crossmember and it seemed to be less noisy...no idea why but it was
