bilstein hd, slp bilstein, tokicos, or kyb adjustables?
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
Pirelli 295's, sportlines, shocks, BFH, adj panhard. im doing all this within the next week. ive been searching stuff on sportlines for over a month, but im not sure which would be better: bilstein hds, slp bilsteins, tokicos, or kyb adjustables? i was originally just gonna go with the bilstein hds but ive seen some good things about the kyb's. thanks.
sportlines will ride horribly no matter shocks you use , are you looking for handling or just looks ?
I would go with bilsteins , and I dont think there is ALOT of difference in between slp and hd ones so I wouldnt worry about that .. what I would worry about is the sportlines ..
yeah im just going for looks and just a little bit better handling. i DD a jeep thats lifted 6.5 inches so bouncy isnt too much of a factor for me im used to it lol. but my exhaust is really tucked ill just have to worry about bottoming out on tracks or bad roads
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Do you already have the sportlines or not ? if not Id go with a different spring , or do you want the car "slammed" ? bottoming out might be a problem for you with those ..
id really recommed not gettign the sportlines, you can get springs made to the hieght you want and the rate, which would be a lot better and not too much more money.
of those choices I'd go with the bilstein HD's. Thats what I run and they're great.
I have KYBs on my 3rd gen, and they're basically half a set up from OEM replacements. Not worth the money.
Bilsteins will go on the turd when i get around to it.
im into the slammed look, and ive read some stuff about people not bottoming out except for railroad tracks and what not. im on the 17/18 combo and my car looks lifted now. the thing is im just trying these out for the summer, and if they really are that bad ill just get the prokit next spring. but hey 99formulam6r, i noticed your in WI, im in southeast wisconsin. im also going for mechanical engineering lol.
