car slams after going over a speed bump
Like the title says when I go over a speed bump my car slams down hard only on the pass side I replaced the struts and shocks yesturday thinking that would fix it but it didn't. I have eibach pro kit springs if that makes a differnc any ideas would help me. Oh and if. Ride the speed bump down really slow it won't do it but I know it shouldn't matter really. Thnx for any help
Location: Oklahoma City, OK/North Long Beach/Paramount, CA
my guess is your slamming your cat, my car did the same thing the previous owner cut the stock springs on stock decarbon shocks which drop my car like 2inchs and when i went over bumps i'd always slam/bottom out hitting my cat which sits under the pass side so i just would drive over bumps slowly to avoid the banging but now i have koni's and hotchkis springs
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I'm sorry should said that both cats are cut off just pipe there now I got under the car just a min ago and I dnt see anything scraping.the slam I'm talkn bout is kinda like the strut bottming out with no bump stop there but I have everything in like its supposd to be wats weird is the first few times I go over the bump it'll bottom out. But sometimes it won't bottom out idk wtf is going on but I know it isn't good had a friend say that maybe my subfram is loose on that side wat do y'all think and sorry for bothring everyone so much it pisses me off when I cnt figure somthing simple out.
Ok I will check the rubber on the arms and the ball joints. And I just got some replacment monros from orlys I know they arnt the best but they have to be better than the 140k decarbons that were on the car and its just the front right doing it. I tightnd everything down with the spring fully compressed. I guess if I dnt find anything wrong ill just drive it till it breaks lol
Mine does the same thing if i go over a speed straight on and to fast. Just learn to go over the speed bumps at a angle and really slow. About 1 tire at a time and you should be fine.
![Icon Smokin](https://ls1tech.com/forums/images/smilies2/icon_smokin.gif)
Ill start doing this but I still want to figure out y its doing it there has to be something wrong I know its not supposed to slam like this
where are you located check your regional forums and see if u can find a local f-body owner give you a hand just an idea. i've solved many problems that way
This maybe a long shot but ive heard of it once. The trans crossmember bolts broke on one side of frame and when you hit a good bump it seperates and hit the floor. Like I said its a long shot but I have heard of it before. Its something just to double check
