Help on C5 Rotor Upgrade
Alright, I want to run the larger C5 rotors on my 2000 T/A and I know I need a relocation bracket to keep my stock LS1 calipers. However, UMI's conversion kit will not work with 17'' Torq Thrust wheels and would require modification of the spindle if they would fit my rims.
My question is, is there a relocation/conversion kit/bracket that will work with my 17'' TT M's and that does not require cutting my spindle?
Thanks
Thanks
Thanks
Thanks
They are roughly the same size as the LS1 pads, maybe just a tad larger, but its nothing that will make any difference.
Pad size generally does not = brake torque. Larger pads however help the pad to run cooler when you are beating on them.
The C5 calipers though are stiffer due to being vacuum cast and and their strengthening ribs. They also have slightly smaller pistons than the LS1 calipers.
Larger pad usually means cooler pad, given the compound is identical.
I can get a set of c5 calipers and rotors and brake booster for 250.
I have a set of LS1 spindles, would the only other thing i need be the brackets?
Is there a difference between the c5 and the c5z06 brakes?
So is the CTS-V caliper larger than the C5 caliper?
I'm starting to drift towards C5 rotors with brembo calipers.
I know the CTS-V is a brembo make however I think the CTS-V rotors are larger and therefore the calipers would be larger and would not be usable on C5 rotors.
