???s re UMI TM Torque Arm with relocation bracket.. which one for me.
I am in need of replacing my torque arm on my 99 Z and want to pick up a UMI torque arm w/ TM relocation bracket and drive shaft safety loop. I currently have AHR LTs and a S60 w/ CM 3" driveshaft. Which one should I buy?
Rob
Rob
I would recommend item # 2201. If you look at the installation pictures in the link below they show this item with a 3.5" Strange drive shaft connected to an S60 with Kooks ORY. The ARH should be very similar... it might not hurt to crawl under the car to be sure the clearance is there.
www.umiperformance.com/2201
I hope this helps!
Ryan
Glad to help you. You should have a 3" drive shaft. I don't think Strange offers a 3.5". They made one for me so we could use it for proto-type use, otherwise I would have gone with a 3" as well.
If you don't already have the exhaust made then yes you could run underneath it or on the outsides of it. What we would suggest is to install the torque arm and have the exhaust built around it.
I hope that helps,
Ryan
I hope that helps,
Ryan
